Speakers based on beyma 15xa38nd - diyAudio
Old 4th June 2015, 05:29 PM   #1
Zoef is offline Zoef  Netherlands
Zoef's Avatar
Default Speakers based on beyma 15xa38nd
Hi guys,
Need some help.
I want to build some speakers based on the beyma 15xa38nd coaxial drivers.
No extra tweeters or woofers. Just the beyma's. A bit like the old tannoy's.
What i need are some plans for the enclosures. (And some crossover schematics, if there are any)
I prefer mltl, tqwt or ported boxes.
If possible, could someone hook me up with some plans?
Hope someone can help me.
Sent with tapatalk from a lazy chair......
Old 5th June 2015, 04:57 PM   #2
GM is offline GM  United States
GM's Avatar
Greets!
I neither do drawings, just provide basic dimensions, nor design XOs, so tweaking the stock one is all I can recommend.
For cab alignments, what are your room dimensions and where they will be located, listening distance [Lp], max physical cab dimensions, average seated ear height and are you open to maybe having the driver somewhat above it if thereís no cab height restrictions?
Also, what type electronics will drive these and if tube, then ideally need its output impedance [series resistance, not tap value unless itís a matching impedance amp with a damping factor [DF] = 1.0].
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th June 2015, 05:04 PM   #3
Zoef's Avatar
My room is about 4.5 x 7.5 m. Maximum height would be about 1 m (maybe little more) and about 50 cm width and depth.
I want to use a (diy) pass aleph 3 . 30w class a. Would be serious overkill i think.
Old 5th June 2015, 05:07 PM   #4
Zoef's Avatar
I found a grf cabinet plan for the beyma's.. is that a good enclosure for it?
Old 6th June 2015, 12:00 AM   #5
GM's Avatar
The GRF is a back loaded horn, so odds are the Beyma's specs are not compatible, but will need the driver specs it was designed for to be sure.
GM
Old 6th June 2015, 12:09 AM   #6
freddi is offline freddi  United States
freddi's Avatar
it would "work" with the original Karlson K15 - you might use it in a straight MLTL too http://img825.imageshack.us/img825/5469/k15k.png
Old 6th June 2015, 01:33 PM   #7
xrk971 is online now xrk971  United States
xrk971's Avatar
That's a nice driver. 99dB, 0.29Qts, 4mm xmax, 2in coax CD, Nd magnets, 350watts program. Wow must cost some change.
http://www.beyma.com/getpdf.php?pid=15XA38Nd
I agree that Karlson K15 would be a very effective cabinet that would be very matched and knock you out of your socks at full power.
For deeper bass extension, maybe an XKi?
Old 7th June 2015, 06:21 PM   #8
Zoef's Avatar
Thanks freddi !
Going to take a look at this.
My wife agrees with the dimensions .
Always helps.
Don't read many positive reactions on these cabinets though...
Looking for some in home enclosures. Best possible sound.
Old 7th June 2015, 06:28 PM   #9
ashok's Avatar
Yeah, 520 green backs at US speakers !
AM
Old 7th June 2015, 06:35 PM   #10
Zoef's Avatar
GM: Freddi posted the driverspecs.
On this site the grf for the beyma's are posted: http://forum.speakerplans.com/15-sco...opic90924.html
As you can read he modified the horn. But if this is a good one.... i don't know.
WTB: Beyma 15xa38nd matsj Swap Meet 2 5th June 2012 08:50 AM
Additional info for the Beyma 15XA38Nd eeyore Multi-Way 0 16th April 2011 11:20 PM
Bi-Amping some Beyma speakers Mark Hatlen The Lounge 0 12th January 2010 05:27 AM
Opinion on the speakers Beyma. widi Multi-Way 0 10th October 2008 06:24 PM
BEYMA 15XA38Nd 15" Coaxial Driver SEIJI Multi-Way 0 5th June 2006 04:25 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
