12" tannoy paper coax and box type. Karlsonator or...?. - diyAudio
Old 11th May 2015, 09:58 PM   #1
Default 12" tannoy paper coax and box type. Karlsonator or...?.
I have gotten a pair of Tannoy 12" paper coaxials to build my friend good quality outdoor PA speakers.
Tannoy CMS 12/8 Dual Concentric Ceiling Speaker. The factory specs show a ported box.
I will need to build boxes. Other than a standard ported, does it make sense to consider and try other enclosures in the attempt to squeeze out max performance from these drivers?
TQWT/Karlonator/Sealed TL??
thanks.
Herman
Old 11th May 2015, 10:51 PM   #2
chrisb is offline chrisb  Canada
If T/S parameters are not readily available, and you don't have the wherewithal to measure for yourself, I'd be inclined to follow the manufacturer's recommendation. If you retain the net cubic volume and port size, you can play around to a degree with dimensions to suit aesthetics.
( insert memorable witty signature line here)
-new favorite: "art is how we decorate space, music is how we decorate time"
Old 12th May 2015, 06:19 PM   #3
frugal-phile(tm)
planet10's Avatar
What Chris says. We did do a miniOnken for a 12" Gold, we measured its specs directly. Performance was OK (bass was excellent). The driver really needed at least an XO rebuild (40-50 year old caps would be long past their best).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th May 2015, 08:35 PM   #4
I am still waiting on my order. Will measure them as soon as I receive them and post measurements.
Old 12th May 2015, 08:57 PM   #5
freddi is offline freddi  United States
freddi's Avatar
a Karlsonator12 would probably be fine
Old 12th May 2015, 09:18 PM   #6
That's what I was curious about: Karlsonator vs vented box...
Old 13th May 2015, 01:03 AM   #7
freddi's Avatar
I tend to avoid vented boxes
Old 14th May 2015, 04:41 AM   #8
Default what box to build?
Got the drivers, measured the 12" paper cone (tweeter and crossover disconnected).
Measurements on a open baffle test board:
No "Vas" yet. Is this needed at this point?
Old 14th May 2015, 04:57 AM   #9
Greg B is offline Greg B  United States
Cool. These newfangled measurement devices really do make things faster and easier.
Yeah, you do need Vas. Necessary to see how big the box should be. Got double stick tape and a few nickels?
Old 14th May 2015, 11:52 PM   #10
xrk971 is offline xrk971  United States
xrk971's Avatar
I use a donut made of plastic modeling clay. Or a donut made of silly putty which doesn't leave a residue in sensitive surfaces. Weigh the clay with a gram scale. The clay is sticky enough to stick to cone and dust cap interface.
Karlsonator 12 for 12LTA freddi Full Range 31 1st January 2015 07:51 PM
can anyone tell me about RADIAN COAX 12" tim614 Multi-Way 25 28th August 2011 02:52 PM
Tannoy Monitor Gold Type LSU/HF/12/8 Osteele Multi-Way 6 21st October 2006 03:27 AM
Tannoy 12" jcmjrt Multi-Way 11 7th October 2006 12:28 AM
Tannoy Monitor Gold Type LSU/HF/12/8 Osteele Swap Meet 0 2nd April 2006 03:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
