Choosing the right components for small enclosure - diyAudio
Old 28th April 2015, 07:24 AM   #1
Default Choosing the right components for small enclosure
Hi all, new user, noob, be nice.
I've currently started a project where I restore an old shelf-radio:
It's a old AM-receiver, which will have a new tube amp (probably the S-5 8LM, but I'm open to suggestions) and a full range speaker. It's a mono-setup, and it has a quite roomy speaker-compartment, it currently accomondates a 8" speaker in a closed design - no bassport or horn, just a lot of 40's dusty sound-dampening material. The wood quality is good, so Cutting out a bass-port should not be a problem.
So the question is, are there any good ways on choosing the correct full-range speaker for this enclosure? Either by calculation, or by someones experience. I'm looking / listening for that old, warm, soft radio-sound.
I'll provide measurements and drawings later on in this thread, for now I'm doing the woodwork finish and restauration.
best regards
Vegar
Old 28th April 2015, 12:32 PM   #2
chris661's Avatar
I'd probably go for an Alpair 12P, and add a rear bass port. There are some standmount ported boxes around somewhere. Should do the job nicely if you can make the cabinet airtight - could be a problem for valve amps unless you go for some clever porting...
Chris
Old 28th April 2015, 12:37 PM   #3
Thanks!
I'll check it out, airtight isn't a problem, since the cabinet is is divided.
What if I wanted the bass port to point downwards, since I need to put this close to a wall ? (this is probably a noob question but...)
V
Old Yesterday, 06:02 PM   #4
Ive been attacking the problem by stripping every thing out, adding a class D, then using full range drivers, in stereo.
Typically I add a raspberry pi for internet radio, then a Bluetooth receiver!
Dave
Correctly choosing type and quality of components arjunm009 Parts 4 24th December 2014 12:50 PM
HiVi D6G 6" - Need help choosing components please :) Bobcat19 Multi-Way 8 11th April 2014 02:39 AM
Help choosing tweeter for 2 way enclosure. greyhnd Multi-Way 18 8th March 2014 11:06 PM
choosing an enclosure ed2000145 Full Range 0 11th May 2009 12:57 AM
Choosing components for DIY Headphone Amp Lumbermatt Headphone Systems 0 7th January 2008 10:41 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
