Fostex fe203 en-s - diyAudio
Old 14th April 2015, 10:41 AM   #1
Default Fostex fe203 en-s
I have a pair of these drivers which I've been using in horns with great results, I'd like to move them to a different location where space will be a problem, hence would like to try them in sealed boxes and use a sub. Is the size of the box critical in this context? I'd be very grateful for any thoughts on this subject.
Old 16th April 2015, 07:52 AM   #2
Anyone?
Old 16th April 2015, 08:16 AM   #3
I had mine in a 8l box. They where usable to approx 200hz. I also tried a 30l box With a Scanspeak variovent (Aperiodic box). They rolled off at 100hz, and actually sounded better.
Old 16th April 2015, 08:20 AM   #4
Thank you Johan.
Old 16th April 2015, 09:04 AM   #5
It wasnt pretty, but sounded great.
4x12" in ripole from 30-200, and FE203en-S in aperiodic box.
Old 16th April 2015, 10:19 AM   #6
That's interesting Johan, how low do you think you go this way (minus sub.) I need 140hz or lower. Is that a Raal? Pretty not important with a prototype, looks very impressive.
Old 16th April 2015, 10:38 AM   #7
140hz is definately possible with aperiodic. The rolloff in the 8l box was not too steep, so with a clever crossover you should be able to cross there with CB too.
Yes it is a Raal 140-15d. IMO a perfect tweeter with FE203. They have nearly identical sensitivity crossed over at 3000, and you avoid the breakup of the whizzer. I crossed 4 order LR.
Old 16th April 2015, 12:06 PM   #8
One last question, did you put much stuffing in the box with the variovent?
Old 16th April 2015, 12:37 PM   #9
No, very little. Just insulation material on the cabinet walls. It sounded very unconstrained. I liked it. Maybe more snap in the closed box though...
Old 16th April 2015, 03:34 PM   #10
Many thanks, I'll keep you posted.
Fostex FE103 EN and FF85WK box volume pk2carlos Full Range 10 22nd August 2014 01:24 AM
Fostex FE 126 En satyakibanerjee Full Range 22 19th November 2012 09:52 PM
Fostex's FE203/6/7/8's in small BR box juanito Full Range 20 20th February 2012 10:07 AM
Fostex fe206 en yek Full Range 3 16th November 2011 12:37 PM
Fostex FE203 congari Full Range 0 20th October 2005 09:12 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
