PVC pipe speakers
PVC pipe speakers
Old 8th April 2015, 11:08 AM   #11
bogdan2011 is offline bogdan2011
You're right, they're very sensible regarding the placement and the room. When you have a driver that's big enough (like a subwoofer), it doesn't really matter if the room sounds bad. The bass will probably sound like crap, but you'll still have plenty of it.
I also have some BRs with 6.5 inch woofers and they struggle with the room too.
Old 9th April 2015, 12:16 PM   #12
glenv6 is offline glenv6  United States
Originally Posted by bogdan2011 View Post
Wow, sounds cool! Do you have any pictures?
I have the pictures in post #2 and here is one of the woofer laying on the baffle on top of one of the tall pipes. I will start a build thread in for my speakers in the multi-way section in the next few days.
Old 9th April 2015, 06:25 PM   #13
How did you cut those rings? The woofer is way bigger than the pipe, so it needs a baffle that can be fixed on the pipe and on which to fit the driver. I bought a router but I have no idea how to fix the baffle to the pipe.
Old 9th April 2015, 06:53 PM   #14
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
use hot glue (gun). and use the saw to make some rough lines so the glue grips (enhances the area of glue attach and stops movement ); also an electric drill to make the surface "rough"
Old 10th April 2015, 02:49 AM   #15
I cut the rings out of MDF with a router using a Jasper Circle jig. If you're going to build speakers you have to have a good circle jig. The model 240 makes circles from 1 inch to 18 3/16 inches in 1/16 inch increments. You'll want the polycarbonate version. I used epoxy to glue the rings to the PVC. They are never coming off. I'll show it all in my build thread.
The RS225-8 is actually the perfect size for 8 inch schedule 40 PVC pipe so the rings are just a nice solid mount for the drivers. Here's a picture showing the speaker laying on the pipe over a piece of foam. I actually used the speakers this way while I designed and tested the cross-over. I was surprised by the fantastic sound they produced without being secured to anything!
Old 10th April 2015, 05:36 AM   #16
I never had one. Nor a mic
Old 10th April 2015, 11:37 AM   #17
I like the speed and accuracy of the circle jig. I used a jigsaw at first but spent too much time cleaning up imperfections....
Old 14th April 2015, 05:57 PM   #18
Some more recordings:
https://youtu.be/3OJWVE7yS4k
https://youtu.be/WaMlnVfmeZo
Old 14th April 2015, 06:13 PM   #19
Greg B is offline Greg B  United States
Yeah, a Jasper jig will yield better results than a saw for most speaker building circle cutting needs. I always find it a pain to get the pin thing in the right hole though.
Anyhow, cool PVC pipe speakers! Nice to see someone actually place the driver at 1/3L with a T fitting for the 'mid' pipes. Mostly we just see end loaded TL pipes. I can understand end loading the big ones, as the increase in gain is likely a worthwhile tradeoff, and the exits are distant enough that there probably aren't going to be any huge nulls - compared to room effects anyway.
Old 15th April 2015, 02:50 AM   #20
The most challenging thing for me was figuring out where to put the pin to cut a disk of a specific size. The jig is designed to cut holes, so if for example you want an 8" disc rather than an 8" hole you have to add 9/16" to the end state measurement so the jig cuts the disk to that desired size.
Thanks! I have to credit Martin King and his spreadsheets for the design. The speakers came out sounding great without second guessing. PVC did allow me to play around with the lengths and I found myself going back to the calculated lengths every time. They just sounded best that way...
PVC pipe speakersHide this!Advertise here!
PVC sewer pipe speakers andyjevans Full Range 19 2nd December 2009 11:58 AM
Old, old, PVC pipe design... Ronmeister Multi-Way 6 5th June 2009 11:55 PM
PVC Pipe speaker ideas chipco3434 Multi-Way 5 29th May 2009 05:36 AM
Finishing trim for PVC pipe eRiCdWoNg Multi-Way 1 3rd May 2004 03:17 PM
How could I shrink some 2''PVC pipe Guss Multi-Way 23 21st February 2004 07:02 PM
