Have you heard of Juhazzi's Aino Gradient?
http://www.diyaudio.com/forums/multi-way/231353-aino-gradient-collaborative-speaker-project.html
I've read very interested
zen dipole open speakers is low budget
total 133 euro
total 133 euro
foam between the woofer and ground (is excellent)Hmmm... woofer's bobbin shouldn't lay on metal
BTW nice woofer !
Car woofers cost 35 euros eachBTW nice woofer !
Recforce woofers, with self made silicone coating
https://www.conrad.nl/nl/renkforce-auto-subwoofer-chassis-300-mm-500-w-4-370335.html
I meant, the inductor ( copper bobbin )foam between the woofer and ground (is excellent)
If the plate is aluminum, no problem ( I guess )
No problemI meant, the inductor ( copper bobbin )
Foto, Akai AM-U22 amplifier and the modded Philips cd160 player.
Hi koolstofje,
Some kind of funny project you've done,like it somehow
I have seen your new video and you have removed the dust-caps of your woofers.
Can you probably explain why you did this?
Have you heard a change in sound or is it only an optical liking?
I thought that as long the caps are not porous, you will reduce the effective radiating area - Sd...lowering the weight of the membrane and resulting with a higher resonance-frequency...
This speaker can be set anywhere?I've read very interested
total 133 euro
Foam is used to make it more comfortable so that it can't burst if the sound is louder.
The layer has been tightened without-caps-caps. And the acrylic coating makes it completely dry low!Hi koolstofje,
- Full Range
- Zen Dipole Open Speaker
