Equivalence between different drivers - diyAudio
Old 26th February 2015, 10:56 AM   #1
Default Equivalence between different drivers
Hi everybody. A technical question. Which of T/S parameters have I to compare to decide if two different drivers are "equivalent"? This both in bass reflex and back loaded horn configuration. For example, Fostex Fe 206 En compared with Tang Band W8 1808. These two drivers can be used in the same bass reflex cabinet, but how can I understand if this is in general true?
Many thanks in advance
Ziocalepino
Old 26th February 2015, 11:13 AM   #2
Did it Himself
richie00boy's Avatar
It is not so much about comparing one paramater, what matters is the synergy of parameters. It is more difficult in a vented box to do, but the best way to compare is to model each driver in the same box and see what the results are. WinISD Pro is good for this.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 26th February 2015, 11:22 AM   #3
xrk971 is online now xrk971  United States
xrk971's Avatar
The big ones to look at (besides obvious fs and Sd) are Qts and Vas. Those two really play a big role with giving a picture of the relative amount of motor strength vs mechanical damping and how big of a box will you need to reach the fs a typical box.
Old 26th February 2015, 12:34 PM   #4
Scottmoose's Avatar
Pretty much all of them, but Qt, F0 (more commonly written as Fs) and Vas are the critical ones as far as box alignment goes. To that you should include the output impedance of the amplifier, when possible since this will affect the alignment.
Typical back loaded horns are essentially just an extreme variation on the bass reflex theme.
Can they? That's news to me. If you stuffed them into the same volume with the same tuning frequencies they will have significantly different alignments.
It usually isn't. Very few drivers can be stuffed into boxes designed for something else with vaguely reasonable results. Some manufacturers claim otherwise, but the laws of physics are against them.
Community sites www.frugal-horn.com http://frugal-phile.com/
Which diode specifications for equivalence? brucew268 Power Supplies 15 11th September 2014 11:57 AM
port equivalence toobhed Full Range 3 3rd August 2013 05:41 AM
Slot port vs circular port equivalence Brisso57 Multi-Way 12 21st February 2009 02:38 PM
Open-Baffle dipoles...a heresy to pair PA drivers w/ home drivers? thadman Multi-Way 7 11th November 2006 09:11 PM
equivalence electric and mechanical (acoustic) correction SPL alex0 Multi-Way 2 26th February 2004 11:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
