FE108EZ in a Frugel-horn?
Old 14th February 2015, 05:21 PM   #1
jjcarr is offline jjcarr  United States
Default FE108EZ in a Frugel-horn?
First off, finished my 2nd "Fraggle" horn and I'm very impressed. The designer did an excellent job. I like the sound of the Fostex drivers. Tried a MA driver a while ago and it didn't do it for me. Right now I'm running the ff105wk in them, and the results are quite good.
Would the FE108ez or FW108n be any kind of improvement in the FH, or even work in it? Happy with the speakers so far, but always looking for improvement if it's viable.
Old 14th February 2015, 05:26 PM   #2
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
I'm guessing maybe less bass with the 108? Which MA driver did you try?
jeff
Old 14th February 2015, 06:02 PM   #3
I did the Alpair 10p in a larger encloser. It was warmer, for forward, but in the end loss detail compared to the Fostex. The MA drivers are also more forward, and I prefer a more laid back sound.
Old 14th February 2015, 06:16 PM   #4
Here's a crappy pic of the rough-finished pair. Once I finalize on the preferred driver I'll veneer them.
Old 14th February 2015, 06:40 PM   #5
chrisb is offline chrisb
By all reckoning, yes, the 108 would work in the FH3, likely with less bass extension and "slam" than the FF driver. If you're still curious about other drivers that might work, and have the budget to consider the 108Sigma, I think you ow it to yourself to try the Alpair7M.
like my mind, this space intentionally blank
Old 14th February 2015, 07:03 PM   #6
vinylkid58's Avatar
That's interesting. I would have said the opposite.
jeff
Old 14th February 2015, 07:15 PM   #7
djn is offline djn  United States
djn's Avatar
Are you using new drivers? Those can take a hundred hours to break in, and only then will you know what you have.
Old 15th February 2015, 01:22 PM   #8
Joseph Crowe is offline Joseph Crowe  Canada
This looks like a home theatre application judging by the picture. Results vary widely depending on source quality and the amplification used.
Old 15th February 2015, 02:25 PM   #9
Godzilla is offline Godzilla  United States
Godzilla's Avatar
Looks good to me. Enjoy the fraggles! Heard so many mixed reviews about MA drivers. It's difficult to pull trigger to buy a pair.
Old 15th February 2015, 02:41 PM   #10
Drivers are well broken in. Normally, yes, any home theater application wouldn't be ideal. But I'm using a Meridian Pre/Pro and an ICEPower amp. I had various tube preamps in the past, BAT vk3i, Bottlehead, and a few others. The Meridian amazed me because I replace the BAT with it and lost nothing in musical quality. It's the only theater preamp that I've used that I'd consider suitable for good audio. For curiosity I put an NAD setup and Adcom setup in when I still had the bookshelf Fostex setup and it was painful to listen to. Even the Lexicon sounded harsh.
FE108EZ in a Frugel-horn?Hide this!Advertise here!
Frugel Horn kp93300 Planet 10 hifi 8 14th September 2013 06:08 PM
Spawn of Frugel-Horn planet10 Full Range 1675 14th March 2011 05:59 PM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
