Karlson Questions - diyAudio
Old 3rd February 2015, 10:49 PM   #1
Default Karlson Questions
Hey howdy, kindreds. Still wacking away at parabolic vents here. Got a couple questions for you.
Are there any K-style subwoofer designs with geometries differing from the usual? I mean on purpose, with consideration and calculation afore thought. Such as, needing a longer taper to separate the lower frequencies more, or no need to go all the way up to a narrow point due to no high freq?
And, has anybody worked out the topology of the physical inverse of the vent, an appropriately curved reflector?
Old 3rd February 2015, 10:57 PM   #2
freddi is offline freddi  United States
freddi's Avatar
approaching one as a series 6th order bandpass is logical as would be a transflex variant XKi - X's ab initio Karlson 6th Order Bandpass
Carl and Wayne used wider starting points for the aperture than usual as the aperture wasn't needed to work into the high frequencies
- - look at the subwoofer in the middle of this picture. This little passive radiator sub augmented eight 10" Scan-speak woofers in aperiodic boxes
although not a real design from scratch, this design from TB46 with a Karlson-ish or "Nineleaves" style aperture
makes a smooth graph from 20 to 200Hz with an Infinity 1260W.
In this case, a round or rectangular aperture may have less "chuffing."
you can see one person just stacked up a few woofers
Old 3rd February 2015, 11:17 PM   #3
xrk971 is online now xrk971  United States
xrk971's Avatar
A custom XKi can be made to hit just about any freq you want and have wide bandwidth and good cone control for high SPL. I have a design with a single Faital Pro 12HP1030 that can hit 120dB at 36Hz in a 2cu ft box.
A large Karlsonator variant like the MOAK which was proposed but never built could also work.
MOAK: The Mother of All Karlsonators (aka The Magnificent Monster)
who's using the Karlson ? freddi Multi-Way 3 19th January 2015 09:09 AM
Karlson freddi Full Range 238 11th December 2014 08:53 PM
Starting down the Karlson road with some questions JChrisG Full Range 21 15th October 2014 01:41 PM
when are you going to try Karlson? freddi Full Range 2 20th November 2007 09:45 PM
Karlson Kolumn PeteMcK Multi-Way 0 16th November 2007 09:08 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
