XKi - X's ab initio Karlson 6th Order Bandpass
Old 16th September 2017, 01:19 AM   #711
xrk971 is offline xrk971  United States
xrk971's Avatar
I like the 24L 10in wide format too. My main RS225/10F speaker is 24L and looks nice.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 16th September 2017, 06:45 AM   #712
freddi is offline freddi  United States
freddi's Avatar
would you make the inside height ~14"?
Old 16th September 2017, 09:08 AM   #713
xrk971's Avatar
Probably 15in high and ~10in deep.
Old 16th September 2017, 10:00 AM   #714
freddi's Avatar
- so the front chamber about 4" deep at its top (?)
Old 16th September 2017, 01:07 PM   #715
xrk971's Avatar
Yes. The math works out that way - for 20% front chamber, depth needs to be 40% of total so 10in x 0.4 = 4in.
Old 16th September 2017, 08:02 PM   #716
freddi's Avatar
so the finished build will be about 12" deep x 11.5" wide by 16.5" tall - 5/8" BB or 3/4" "Araco" plywood. 1/2" BB might suffice with a few braces. It would be nice to make the wings rather "dead" from some laminate.
I've only one FE206EN so an XKi might be the 34 liter version for SN10C. The 60 liter XKi for 1772/Beta10cx is a bit big for my little bedroom.
Old 17th September 2017, 06:24 AM   #717
xrk971's Avatar
I think 1/2in BB would be nice to keep the bulk down.
Old 17th September 2017, 06:38 AM   #718
freddi's Avatar
the FE206 XKi is just a bit larger than Beta8cx XKi Click the image to open in full size.
Beta8cx in the XKi should sound pretty good on female vocals when things are right
would FE206EN XKi's aperture look as "constricted" as with the image above?
Old 17th September 2017, 10:44 AM   #719
xrk971's Avatar
That plan for the Beta 8Cx looks almost about the same as for the FE206E. Vent is also 0.75 deep but 10.0in long. Cabinet on FE206E is an inch taller and depth an in deeper, with a 4in deep setback on the front chamber.
Old 17th September 2017, 03:12 PM   #720
freddi's Avatar
with some foam blocks in the rear chamber, the Fostex version could also accommodate Beta8cx (?) - - (maybe others ?)
out of all of your K models - which one might you most easily add a stub feature to the front chamber? - Could that be useful to quell the peak seen right before the "W" fill area in K15 type? Is it useful on the XKi where the sim shows substantial rise to a peak ? (typically 200-300Hz)
XKi - X's ab initio Karlson 6th Order BandpassHide this!Advertise here!
6th order bandpass question tinitus Subwoofers 13 8th March 2009 06:01 PM
6th order bandpass Chris8sirhC Subwoofers 1 13th September 2008 07:09 PM
6th order bandpass subwoofer Ilianh Subwoofers 50 25th January 2003 01:40 AM
6th-order Bandpass BAM Subwoofers 1 24th September 2001 05:51 PM
6th order bandpass design? SubNut Subwoofers 3 22nd September 2001 08:48 PM
Copyright ©1999-2017 diyAudio
