New TB for 2015 - diyAudio
Old 24th December 2014, 03:37 AM   #1
Default New TB for 2015
Just got an email from TB and they were showing new 2015 models.
Here it is:
1. New full range serie – from 6.5” to 8”
W3-2141
W4-2142
W5-2143
W6-2144
W8-2145
This series has very nice performance full range, we make them in ferrite magnet version, it should be categoried into economic models..
2. More “module” be developed
T1-1828SD – square shape in alum. Cone. Passive radiator in
the backside.
T1-2121SD – rectangle shape design, increase power
handling.
Module = speaker box, which is getting popular in the market, with passive radiator design in a sealed box, it widen application possibility from portable speaker, multimedia to soundbar system. It is a total solution for most of application includes cross-industry application like LED light bulb, furniture….. You only need to focus on designing amplifier functions and ID design of finished products.
3. Micro speaker – we increase its size from 1” to 2”
W1-2121S – high power handling, consistent quality
W2-2136S – good linearity, consistent quality, good low fo.
W2-2181S - – good linearity, consistent quality, good low fo.
Recently, we developed many micro speaker, those are
4. Low distortion Subwoofer - 3” and 6.5”
W3-2108 – thinner basket than W3-2088S0F
W6-2100 -2014 we already had 2” – 8”, but we miss 6.5”, so we add it here.
This series subwoofer have extremely linearity and low distortion characteristic , dual surround and no spider,
Old 24th December 2014, 10:07 AM   #2
Scottmoose's Avatar
The module etc. series hold about as much interest for me as The Only Way is Essex; the others look a trifle more so though. Spec. sheets for the W3 - 8 are on TB's site:
http://www.tb-speaker.com/detail/1230_04/w3-2141.htm
http://www.tb-speaker.com/detail/1230_04/w4-2142.htm
http://www.tb-speaker.com/detail/1230_04/w5-2143.htm
http://www.tb-speaker.com/detail/1230_04/w6-2144.htm
http://www.tb-speaker.com/detail/1230_04/w8-2145.htm
They look nice enough aesthetically, although personally I don't much like the shiny santoprene roll-surround & I can't imagine it'll do the off-axis response many favours; the published impedance curves on the data sheets suggest that there are some resonance issues from this, probably reflections, although we shall see. I do like the colour of that bamboo derived paper. The phase plug reminds me of tuning dials on 1970s era receivers (I quite like that). Possibly solid extension; be interesting to find out.
On paper the specs. appear reasonable for what they are; W3 has a very low F0 + moderate Q -looks like they're trying to do a Fostex wk style driver with a bit more low-end. Don't like the HF rise -theoretically. That may smooth out off-axis though & TB's graphs have historically needed to be taken with a pinch of salt. Be interesting to see what transpires. W4 much the same -Q's a bit lower though & the top end seems a bit disappointing, but since it goes off the scale, difficult to say. W5 looks promising; nice balance of spec. for a variety of cabinet types, response doesn't look too bad on axis (with aforementioned caveats). The W6 & W8 are interesting, although the whizzer cone on the former looks from the pictures to me like it might blank off part of the main cone off-axis, so might be an issue depending on where the mechanical XO is -from the look of the impedance curve I'd guess about 2.25KHz. All in all, not without interest.
Community sites www.frugal-horn.com http://frugal-phile.com/
Old 24th December 2014, 01:46 PM   #3
hkk is offline hkk  Finland
Hmm, w4-2142 - I'm wondering if this works with BLH or BIB enclosure?
Old 24th December 2014, 02:38 PM   #4
Scottmoose's Avatar
The BIB is a back horn.
They'll all work -just a matter of degree.
Old 29th December 2014, 09:10 PM   #5
http://www.tb-speaker.com/detail/1230_04/w6-2100.htm
is it 6,5"?
Old 30th December 2014, 02:00 PM   #6
Godzilla's Avatar
Looks like they are gunning for Fostex. I like everything but the thick rubber surround.
Old 31st December 2014, 04:16 AM   #7
freddi is offline freddi  United States
freddi's Avatar
that is a wooferish looking surround on the 8 - is it ~the same as Santoprene? - slug magnet
Old 31st December 2014, 09:18 AM   #8
Bill poster's Avatar
They are an update on the designs with that weird fake copper phase plug.
I think they missed a trick not having a 6" without the wizzer - the 5" wd be great with a bit more xmax
also they don't look like neo magnets but I guess they must be if they say so
edit def ferrite, must be reusing modified spec sheets
Old 31st December 2014, 10:38 AM   #9
Scottmoose's Avatar
Probably; they're certainly ferrite magnets & this is noted in a couple of the sheets. Presumably the subediting missed that in the others.
Old 31st December 2014, 10:05 PM   #10
I like what TB have done with the plug, I know there's a consensus that any kind of phase plug in a wideband is a bad thing but what the hell, it looks nice. I like the look of the white cone with the silver plug but def not keen on the shiny surround.
Guessing the 4" will be popular as a mid as well as FR, the 5" as a ribbon companion in a 2 way. Both have flat response up top, if the charts are accurate
Its a shame they don't look to have much cone travel, altho maybe the xmax rating is misleading.
DIY Audio Ottawa 2015 mwmkravchenko Clubs & Events 55 Today 12:22 PM
UK to go DAB by 2015 AndrewT Digital Source 4 21st June 2009 10:56 AM
Op Ssm-2015? Marcelo Analogue Source 2 27th January 2003 10:31 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
