What a good speaker enclosure design? - diyAudio
Old 10th December 2014, 07:45 AM   #1
Default What a good speaker enclosure design?
Hey guys,
I have these two 3 inch speakers and a 4.5 inch passive radiator.
I'm looking to put them all in an enclosure with a battery. I'm an electronics guy but I have no idea about sound. What's the best setup for a speaker enclosure? I've read some articles saying the PR should be on the bottom and some that it should be elsewhere.
Old 10th December 2014, 03:45 PM   #2
Speakerholic
Cal Weldon's Avatar
I've moved this over to the FR section.
Is there any information about the 3" speakers? Can you show front and back shots?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 10th December 2014, 05:01 PM   #3
sure, these are the speakers.
Fountek FE83 3" Full Range Driver 8 Ohm
Old 10th December 2014, 08:42 PM   #4
mikje is offline mikje  United States
Soakin' up the Sound!
mikje's Avatar
Buyout FE83 modeling help?
Mike
Marantz PM8003 amp, Jolida SJ502A, Squeezebox Touch, MLTL Continuums, DIY Carmichaels (Dayton, TangBand, Vifa); MarkAudio A 7.3 Frugalhorns, MarkAudio CHP-70s
Old 11th December 2014, 03:37 AM   #5
I'm just not sure where to put the passive radiator. Is it ok to put it in the middle and have each driver on either side? Or should it be on the bottom of the box facing down?
Old 11th December 2014, 04:56 AM   #6
18Hurts is offline 18Hurts  United States
Passive radiators should never be mounted on the bottom facing down (or facing up)
They are tuned with weights and that causes "cone sag" or the weight pulls the radiator
down via gravity. Always mount them on their side for this reason.
Running two full ranges always get them mounted vertically as close as possible together.
The passive radiator can be mounted below the full ranges to give it a more traditional look. Some passives are mounted on the back but that can cause problems if you wall mount them etc.
Old 15th December 2014, 08:28 AM   #7
I have 2 full ranges and 1 sub woofer. Should I go driver - sub - driver. Or put both drivers on the front with the sub on the back panel? Not sure what the best option is for a single enclosure.
Speaker enclosure design confusion ! Ahmad_tbp Multi-Way 3 30th October 2012 11:49 AM
Dr. Leach Very Large Enclosure 3-Way Speaker Design semper avarus eget Multi-Way 4 24th November 2011 09:47 PM
Can any one share a good design(X/O + enclosure) for a XT25 and 7'' HDS Exclusive? AV8ter Multi-Way 17 4th May 2011 09:33 AM
HT Center Speaker Enclosure Design jeromero Multi-Way 4 13th April 2007 08:13 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
