DIY AGC and Bi-quad filtering
Old 28th November 2014, 10:02 AM   #1
arjunm009 is offline arjunm009
Default DIY AGC and Bi-quad filtering
Hello
First my goal is to build a small portable stereo speaker having a "okay" low end and a sound which can fill a small room.
Active Drivers in consideration
1. Dayton Audio CE42p-4
2. Dayton Audio CE56p-4
Amplifier
1. PAM8403: 3W class d
Power source
1. Single 3.7V 2600mAh cell
To complement the low end, a passive can also be used, Peerless 830878.
But the target volume is less than 0.03ft3. Need two drivers in a small enclosure.
Simulating in WinISD Pro, I applied Linkwitz transform to both speakers, in a sealed enclosure, with a Butterworth Highpass filter at 100Hz, respectively. Signal at 3W.
1. For CE42p-4
Box Volume - 0.015ft3
Fsc - 169Hz
Qtc - 1.020
2. For CE52p-4
Box Volume - 0.017ft3
Fsc - 240.45
Qtc - 1.091
The low end, more specifically at 100Hz, the excursion looks no good. Quite damaging. You can see it in the attached image, the white circled region.
Since, these drivers are not capable of wow bass, I am looking for something around 100Hz but definitely less than 140Hz.
Can someone suggest me the corrections to be applied to manage the high excursion at just about the new Fs? Again wouldn't mind a passive.
Is it possible that an AGC would help to control the power delivered in the low end, and thus contain the over excursion problem?
Please note the power source is a single li-ion cell.
Thank you.
DIY AGC and Bi-quad filteringHide this!Advertise here!
Calculation of Digital Bi-quad Filter Coefficients dshyam91 Digital Line Level 2 27th July 2013 04:19 AM
Active filtering or new cross-over for DIY 15 inch homecinema speakers? vandevoordekoen Multi-Way 42 11th October 2012 02:28 PM
Is the EXAR XR-084 quad bi-fet opamp any good? cyclecamper Solid State 26 23rd March 2012 03:17 AM
First DIY - bi amped 2-way standmounts valleyman Multi-Way 21 20th February 2008 10:38 PM
bi-amp for diy speakers biff584 Multi-Way 7 15th November 2002 09:23 AM
Copyright ©1999-2017 diyAudio
