Onken Enclosure?
At the moment I'm running some giant 500litre fridge like cabinets with Neo pro5 fountek ribbons, 201 goodmans for high mid, 301 goodmans for low mid/high bass and richard Allan's cg15 15" for bass. I have been thinking of making some onken cabinets for the 201's or maybe the 301's, or both?? I find the 201s have a better treble high mid quality while the 301's have a better low mid bass ...any suggestions?
So been thinking I will build the onken cabinets and run the 201's fullrange for awhile, then the 301's. Then I will introduce the ribbon as a two way system. I will crossover at 5000hz trying both drivers.... Then I will try the 301's in the onkens for the bass and 201's open baffle on top. ....then introduce the fountek as a 3way later on. I've got some fun ahead of me. Has anyone got dimensions for a onken enclosure that would work for both the 12" goodmans?? I found some dimensions for the 201's 98cm high 44cm wide 48cm deep. Does this sound right??? Will this work for the 301's too??
Founder of XSA-Labs
Joined 2012
Seems like this should be in multi way forum? FWIW, I think the Onken cabinets seem like a lot of extra work and extra wood. Having a very narrow aspect ratio vent is used to introduce surface skin drag on the vent as opposed to pressure drag with a more conventional vent. I have heard some people say it sounds nasaly. There are certain parameters that are needed to be maintained for a true Onken alignment. Have you checked the online Onken calculator to see if your drivers and intended bix dinensions are a match for an Onken? You might want to look at a BVR as a completely different alternative that is simpler to build and provides some bass gain.
mh-audio.nl - Home
Thanks for the reply:) I use to run the goodman 301's fullrange in a bass reflex cabinet then open baffle. I then introduced the 15" to get more bass. I really loved open baffle but then had a son so had to protect the drivers so made a cabinet out of my open baffles 1450x600x600. But now I would like to get back to a simpler set up. Either fullrange or 2way with the ribbon. BVR? Do these cabinets work well with 12" ?
Nearly 3am, need to get some sleep will keep looking tomorrow.
These are the T/S parameters for the 301's I would imagine the 201's would be similar:
Fs 34Hz
Qts 0.217
Qes 0.23
Qms 3.4
VAS 311 Litres
Xmax 6mm
Piston area 0.0491 sq metres
SPL 96dB (1W/1M)
Flux density 1.6T
:) thanks for your help!
