Small reflex box FR recommendation? - diyAudio
Old 14th November 2014, 11:24 AM   #1
Default Small reflex box FR recommendation?
Want to put together a pair of computer desktop FR speakers for a gift for a friend. These will hopefully replace some pretty crappy Logitechs already in place. The sub will stay. Want to keep these 10L or less and BR for a bit of bass punch and easier sub integration. Baffle width max is 4.5".
Old 14th November 2014, 11:34 AM   #2
Mayuri is offline Mayuri  Finland
Mayuri's Avatar
For easier sub integration into computer speaker subwoofer I'd make a small sealed box. Maybe Faital 3FE25 (sensitivity) or Vita TC9 (looks)?
Old 14th November 2014, 11:37 AM   #3
sideways's Avatar
Fostex FF85WK in a Lance...if you can live with a 5" width
Woden Design 3" Box Designs
Old 14th November 2014, 12:00 PM   #4
cspirou is offline cspirou  France
The fostex recommended box for the fe83en is about 6L. I made nearly the same thing except I moved the BR port in back. Even though I know the bass isn't there, I don't really feel like it's missing because it rolls off easily. Should integrate with a sub no problem.
http://www.fostexinternational.com/d...pdf/FE83En.pdf
If you don't like the fostex box then check out this Japanese speaker porn.
スピーカー製作
スピーカー製作2
スピーカー図面
The first two links are pictures and the third link has plans to make the speakers. Google translate is your friend. The Japanese love audio and they live in small spaces so they are masters at making great small speakers.
Old 14th November 2014, 12:34 PM   #5
Surprised to not see recommendations for MarkAudio driver? Given the desktop use, I can angle the baffle to reduce the vertical off axis listening position.
Old 14th November 2014, 12:49 PM   #6
mikje is offline mikje  United States
Soakin' up the Sound!
mikje's Avatar
MarkAudio it is...
I put a CHN-70 in a 0.2 cubic foot box (roughly 5.6 liters) per the recommendation on the Madisound page for the driver. This is a great little driver, especially if you'll be using a sub with it.
"In a ported box of 0.2 cubic feet with a 1.5" diameter vent by 4" long (or 1" リ x 1.5" long), your f3 is about 70Hz."
https://www.madisoundspeakerstore.co...ne-full-range/
Marantz PM8003 amp, Jolida SJ502A, Squeezebox Touch, MLTL Continuums, DIY Carmichaels (Dayton, TangBand, Vifa); MarkAudio A 7.3 Frugalhorns, MarkAudio CHP-70s
Old 14th November 2014, 07:46 PM   #7
Thanks Mikje. How's the high frequency production of the Mark? I've read and heard subjective opinions that there's some fatiguing breakup in the 4-7khz range that gets to you when listening for a while.
Old 14th November 2014, 07:53 PM   #8
mikje's Avatar
So far, I have no complaints. However, my ears aren't what they once were.
Mike
Old 14th November 2014, 08:13 PM   #9
frugal-phile(tm)
planet10's Avatar
There are so many... especially if 5-6 litre is still considered small. althou 4.5" baffle width is limiting
What kind of budget for the drivers?
uFonken (FF85wk), uMar-Ken6 (Alpair 6.2p or m) would be my 1st consideration.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th November 2014, 02:15 AM   #10
Budget is $200 for the pair. $40 is used for IKEA Bamboo cutting boards for cabinets. Foam, pvc for port, wire and binding post on hand so $160 for drivers and xo components if any ( contour, BSC, LCR trap.....or none!
In Bass reflex box (vented)-If I make smaller box than what consequences will I have? eliaselias_0 Multi-Way 6 3rd January 2011 04:49 PM
A small recommendation ilovepicles Chip Amps 6 22nd October 2010 11:55 AM
Small Fostex Bass reflex audiophile36 Full Range 16 13th April 2008 10:04 PM
Need Comments on FR Bass Reflex blip1882 Full Range 11 28th September 2005 06:48 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ゥ1999-2014 diyAudio
