Any advice for my first build - Bass Reflex Fostex FF165 - diyAudio
Old 14th November 2014, 08:05 AM   #1
Default Any advice for my first build - Bass Reflex Fostex FF165
Hi gents,
I am new here and glad to be in great company!
Having recently acquired an old Pioneer 6BM8 tube amp (SA400) which is being restored... I have been looking for an efficient speaker to pair it with. After hearing some FE166 in BLH a few months back I have also been wanting to try a Full Ranger being shocked at the imaging from these horns.
As my living space is limited I have settled on trying to get the most out of a Fostex FF165WK in a BR box.
Just hoping for any advice and or tweak suggestions for any changes I can make to the basic Fostex BR box design, in terms of port tuning, port dimensions, cabinet damping, construction etc... basically I need some vaildation that I am on a good path here!
https://www.madisoundspeakerstore.co....5-full-range/
Old 14th November 2014, 09:53 PM   #2
Jim Shearer's Avatar
To get the most from your speakers you will need stands if you build 'monitor' style cabinets. My bias is toward TQWT floor standers, like a Metronome. Mets don't take up much floor space & have high WAF.
Cheers, Jim
A day without music is like a day without food.
Old 14th November 2014, 11:10 PM   #3
Greg B is offline Greg B  United States
I think you'll be fine simply building them to the suggested dimensions. A simple BR with a nice full range driver can be a beautiful thing! (how's that for validation?)
IME a TQWT or conical TQWT (like the metronome) will typically sound bigger, cleaner and more hifi than a typical reflex box. So I guess i agree with Jim, and he makes a good point about floor space. However, a reflex can sometimes be mellower sounding, more forgiving of mediocre source material, and generally quite enjoyable.
Old 15th November 2014, 01:37 AM   #4
frugal-phile(tm)
planet10's Avatar
I don't pay much attention to the FOstex recommended boxes. I am currently listening to a set of solid wood prototypes for the FF165wk compact floorstander (ie Fonken165 CFS). I am very please with them.
more: Mark Audio Alpair 10.x/FF165wk compact Floorstander Intro & Questions
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th November 2014, 04:54 PM   #5
Those do look fantastic Dave! Do you have a drawing for those?
Old 17th November 2014, 07:19 PM   #6
frugal-phile(tm)
planet10's Avatar
Drawings are part of the FF165wk paid planset.
planet10-hifi miniOnken Plan-Set Subscriptions
dave
Old 10th December 2014, 11:18 AM   #7
I am going ahead with Bass Reflex boxes for now and may build something more ambitious when space and time permits.
A few questions for the Bass Reflex cab.. how much and what kind of damping/filler is beneficial?
Also I gather stands are the way to go but wondering if anyone else has experience with Sorbothane half spherical feet to decouple the cabinet from what it is standing on? I have been using these with my AR18s and they seem to have a marked positive effect overall.
Hoping to have my drivers here by Xmas.. 18m BB is being cut this week and my Pioneer amp is recapped and sounding sweet.. just a few more carbon comp resistors to be replaced now...
Old 10th December 2014, 03:28 PM   #8
Godzilla's Avatar
Wow, AR18s! I had AR15s and AR92s. I am very familiar with AR speakers since they were among my favorite brands back in the 70s and 80s.
You will really enjoy the Fostex sound if you are like me. It's brighter than the AR and the details come thru without straining your ears to hear them. You will also notice a more realistic tone to the instruments and a more expressive midrange.
It's all good if it helps you enjoy the music.
Old 10th December 2014, 08:41 PM   #9
Covering 3 sides with ~1/2" thick carpet felt or similar material is a good starting point. Typically, this would be the back, top, and one side. You can use more or less to taste. More damping tends to clean up the mids, but too much tends to make the sound gray and lifeless.
It really depends, but big soft gooey feet aren't a good idea for smaller cabinets IME. There isn't enough mass for the driver to react against, and you'll lose some bass. Small semi hard rubber feet (or spikes if on carpet) work better. With bigger heavier cabinets, soft rubber feet can be useful. Easy enough to try for yourself anyhow.
Aw, nuthing like recapping old amps...! good play to just replace everthing. It's not worth it to chase down the bad ones. Are you replacing the resistors with new carbon comps? They have a subtly different sound than metal oxide.
Old 11th December 2014, 08:05 AM   #10
Thanks Greg B, I think we are constructing our cabinets so the rear baffle will be removable and then can experiment with damping materials a bit. Will also try different feet, did not occur to me that the Sorbothane might absorb too much energy and effect bass response!
I have done all the film and electrolytic caps in the 1969 Pioneer but settled on carbon film resistors.. only about 20 more to go!
Not too bad under there compared to some of the receivers from this period:
Click the image to open in full size.DSC_0321 by bregtje_lush, on Flickr
Fostex FX120 Bass Reflex Enclosure Advice Gerardn3 Full Range 11 8th July 2014 10:50 PM
Fostex FX120 Double Bass Reflex zimmer64 Full Range 21 13th October 2012 12:23 PM
Fostex FE167 double bass reflex Zeptepi Full Range 6 18th October 2011 02:43 AM
Small Fostex Bass reflex audiophile36 Full Range 16 13th April 2008 10:04 PM
Fostex w/ Bass Reflex? theseum Full Range 21 18th April 2006 11:07 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
