Enclosure advice for Mark Audio CHR 70.3 - diyAudio
Old 6th November 2014, 06:16 PM   #1
Default Enclosure advice for Mark Audio CHR 70.3
I recently purchased four of these drivers with intentions on building the Woden Designs Lotus ^ 2 cabinets. I have emailed Scott and he advised that the Lotus and Lotus ^ 2 were actually designed for the version 1 of the CHR and that new designs should be appearing soon. Does anyone have any insight if the version 3 drivers will work well in that design or is there a better option out there? I really like the Lotus or Maeshowe style cabinets. Thanks for any help you can provide.
Old 6th November 2014, 08:53 PM   #2
Scottmoose's Avatar
The current CHR works perfectly in Maeshowe, no issues there.
Re Lotus, I didn't say that a new version would be appearing soon, I said it is in the queue of things we have to do, but we were waiting to ensure the current generation units will not be modified in the foreseeable future before we committed to redesign the cabinets. As is, the 3rd generation CHR will not work all that well. I have replied to your 2nd email -apologies for a few hours delay, but unfortunately, I can't be on-line without pause! I will move the box up the to-do list. The changes will probably only need to be fairly small, but important.
Community sites www.frugal-horn.com http://frugal-phile.com/
Old 15th November 2014, 03:18 PM   #3
Default Build advice
I am getting ready to start my Maeshowe enclosure build and would like to get a little advice or tips on how to mark and cut the curves on the back edges of the side panels. Looking at the enclosure plans it states that the cut out is similar to circle with a diameter of 133 1/2 inches (I think). Any help on translating this arch to a template to be able to mark the panels and cut them would be greatly appreciated.
Old 15th November 2014, 04:03 PM   #4
Greg B is online now Greg B  United States
Google "long compass", and then get your dimensions from an arc calculator such as this one.
Or, for something like this, 133.5" of string and a pencil tied to the end is probably sufficient.
Old 15th November 2014, 05:33 PM   #5
Default Thanks
Greg,
I googled the "long compass" term and using the two stick and three point method will work perfectly! Thanks so much!
Need advice on conceptional ideas using multiple Mark Audio CHR-70's golgiapparatus Multi-Way 2 5th December 2012 09:00 AM
Advice on a Mark Audio Chr-70 project Leon Dupuis Full Range 10 11th August 2011 08:27 PM
F.A.S.T. Project: Tangband W3-315 vs. MARK AUDIO CHR-70, CSS EL-70 or Alpair jockel77 Full Range 13 12th January 2010 12:20 AM
Mark Audio CHR-70 durwood Swap Meet 1 12th August 2009 07:53 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
