Old 21st January 2004, 07:02 PM   #11
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Originally posted by tpenguin
If you want bass lower than ~60Hz, I'd recommend you consider a different driver.
That is exactly what I decided after thinking about it for a while.
I also had BSC on my speakers 4 ohm resistor in parallel with a 1.5mH inductor, so they can get boomy if you put them too close to the wall, or in too small of a room. If I bypass the BSC, they sound much better in a small room, but thin in a larger room.
The design is based on Jim Griffin's speakers that I heard over a year ago at the DIYATL2002 event.
Brian
Old 21st January 2004, 10:09 PM   #12
Rafal is offline Rafal  Canada
Thanks for all your suggestions.
Brian,
What driver did you finally decide on?
Backing up a bit...
What I am ultimately trying to do is improve upon my current speakers which are Tannoy System 800 Active - professional monitors. The rason I am leaning towards asingle driver is to avoid a passive crossover. Basically what I want to improve is percieved realism of the performance. I have heard some nice Linn active setups and that would be ultimate but the bank sys NO.
Can you suggest an approach, hopefully a single/wide range, that would present a major improvement over my existing setup (and not cost me an arm and a leg)?
Rafal
Old 21st January 2004, 10:21 PM   #13
Send a message via ICQ to tpenguin Send a message via AIM to tpenguin Send a message via Yahoo to tpenguin
Brian
Maybe for the best overall sound you should decrease the BSC by about 2dB?
Old 22nd January 2004, 11:17 AM   #14
Colin is offline Colin  United Kingdom
Another option might be the Jordan VTL, on the Jordan website. It isn't a bookshelf design but the commercial version, the Konus Essence, gets very good reviews and is reported to extend the driver to around 50Hz. I believe there are a few people on this and the fullrange forum who have built this design.
Colin
Jordan VTL transmission line
Konus Essence
Old 22nd January 2004, 12:32 PM   #15
I'm currently building some standmount speakers using JX92S's, which I'll post details & measurements of when I've finished fiddling. They're not exactly "bookshelf", at about 15 litres, but roughly the same size as the speakers in your pic. I'm planning on a bass reflex, not TL design, and I'm aiming for a smooth rolloff and good transient response, rather than a boomy highly-tuned one.
A number of reports suggest the driver needs quite a bit of break-in to achieve "full" bass response. This might have some truth to it - out of the box the free-air resonance was about 55Hz, but after an hour of playing LF sweep tones through it, it had dropped by a few Hz.
More later...
Cheers
IH
Old 23rd January 2004, 12:14 AM   #16
Thank you all for your suggestions.
I have considered making the floor standing VTL with Jordan 92's. I even considered pairing it up with a subwoofer. I may still go down that path, but there is something to be said for a beautifully executed bookshelf (like a B&W nautilus 805 Signature).
Ian,
I would be very interested to sread more about your project. can you e-mail me once you have it done?
Old 23rd January 2004, 08:47 AM   #17
Nardis is offline Nardis  United Kingdom
I built 7 litre minimonitors using Jim Griifins design, but using an 2x12mm MDF + 2mm lead sandwich. I put the port on the front and use them without BSC against a brick wall. I also exchanged the foam for a Deflex panel on the rear wall and a ring on the rear of thje driver. I thought this gave more sense of air around the instruments.
The mid is superb but they need a subwoofer. I also found the top a bit harsh especially on orchestral strings. and am in the process of adding Fountek JP3 ribbons, which make a big difference in my first lash-up. I need to make new front baffles now.
I'm crossing at 6k with a first order, but am thinking of going up to 7.5k with a 3rd order, following the xover at
http://www.d-s-t.com.au/Ventura/RibbonTweeter.htm
Jordan JX92 w/ BG NEO 3? flatwallet Full Range 9 25th July 2008 03:26 PM
looking for Jordan JX92 (Pre ”S”)/ JX125 project Earplug Addict Full Range 37 4th March 2008 04:40 PM
Looking for Jordan JX92 units chris ma Swap Meet 0 22nd September 2004 11:35 AM
Jordan Jx92 ANTHONY2181 Swap Meet 1 8th June 2004 07:51 PM
Copyright ©1999-2013 diyAudio
