New Dallas II build question - diyAudio
Old 21st October 2014, 05:15 PM   #1
kr1s is offline kr1s  United Kingdom
Default New Dallas II build question
Hi All
I'm about to start a build of the Dallas II.
I've drawn the design full size on a scrap panel and have noticed something that raises a question.
In the first bend, the cross section of the horn decreases before returning to its original size. See image attached.
A similar exercise on the second bend shows that it increases before returning to (roughly) the original value.
My question is: is this by design and best left alone, or would smoother curves (by using more pieces), maintaining a constant throat size through the turn, be better?
Many thanks for any advice
Chris
Old 21st October 2014, 06:08 PM   #2
Scottmoose's Avatar
If I know Ron, it's probably deliberate.
Community sites www.frugal-horn.com http://frugal-phile.com/
Old 5th December 2014, 10:38 AM   #3
Hello again
I now have my wood and the drivers have arrived - FE208E Sigma + FT96H.
There's been a delay as I needed to make a sled to enable me to (hopefully) make accurate, square cross-cuts on the table saw.
I'm now getting close to the point of making the first cuts, but I have another question.
I've read several times that drivers should be recessed such that the front of their bezel/mounting flange is flush with the baffle.
On FE208E Sigma the bezel is mostly tapered with a small square step at the edge (see picture attached).
So my question is whether or not I need to make a recess equal to depth of this step or whether it is unnecessary.
I notice that the Fostex standard enclosure design has no recess but I also know that their designs are not always considered to be optimal.
As always, many thanks for any advice.
Chris
Old 5th December 2014, 12:21 PM   #4
xrk971 is online now xrk971  United States
xrk971's Avatar
That is a tiny square step that is unlikely to cause any problems with diffraction compared to the shape of the bezel. IMO, no rebate is needed. Looking forward to seeing the build.
Old 5th December 2014, 02:23 PM   #5
Bob Brines's Avatar
Most Fostex drivers are designed to be surface mounted -- The FE and FF series for sure. The F200A is an exception. The frame the the FE208Ʃ, so it can be rabbeted in with a router and circle jib, but the pincushion frames are simply not worth the bother.
B0b
Brines Acoustics Web Site
Old 5th December 2014, 06:22 PM   #6
frugal-phile(tm)
planet10's Avatar
We rebate to hide the step.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th December 2014, 06:45 PM   #7
LOL - all that time I've believed it was because it affected imaging
Thanks for the replies.
Hopefully there will be some progress over the weekend.
Chris
Old 5th December 2014, 06:56 PM   #8
frugal-phile(tm)
planet10's Avatar
On the sigmas, not likely much. Particularily the large ones.
dave
Old 21st January 2015, 09:14 AM   #9
At last a bit of visible progress. Both cabinets are in the same state. Now I'm thinking about finish before final glueing. I fancy white sides and natural wood middle but not sure I have the facilities (and maybe patience) to get a decent painted white finish.
Old 21st January 2015, 09:36 AM   #10
zman01 is offline zman01  Bangladesh
Light(er) colored veneer in the middle with darker veneer on the sides?
If you choose to go that route do think about the staining first, as it can be easy to get dark stain onto the light part...
dallas II haraldkasper Full Range 2 3rd June 2014 06:03 AM
Dallas II vs Kirishima gafhenderson Full Range 86 21st February 2014 09:59 PM
Fostex Dallas II maartentje Full Range 5 25th April 2010 02:18 PM
Dallas II plans Novacaine1968 Full Range 6 13th February 2010 01:42 PM
Where is the Dallas II amisdad Full Range 16 5th November 2005 05:57 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
