I think I want to build a set of horns... - diyAudio
Old 10th October 2014, 10:17 PM   #1
h2oTom is offline h2oTom  United States
Default I think I want to build a set of horns...
Hey, I've been enthralled with horns since I heard a pair as a kid back in the 80s.
I'd really like to build a pair and I'm considering going with a pair of the Fostex FE166En and using the fostex suggested plans. I've built some subwoofer enclosures in the past, but I've never attempted anything on this scale.
I've been told that the Fostex plans aren't very good and that the Frugel-Horn 3 is better. I've also been told that the Lotus design would be better. I was also told that the 6.5 inch full driver may sound like a good idea but in reality I'd be better off with a smaller driver.
The more I read, the more overwhelmed I become. That's why I say I think I want to build a set of horns.
The room these will live in is 11' w x 19' deep. The wall that the speakers will be close to only has one corner on the right, the left side has an entrance opening...so corner horns are out.
I'm still a beginner and I'm trying to learn as I go here.
Any thoughts, comments, or suggestions are greatly appreciated.
Old 10th October 2014, 11:02 PM   #2
There's a time-honored tradition of starting off with a simple ported box. It won't be your last speaker, but it gets you further down the road. And given your choice of driver, maybe check out these two articles:
Arpeggio Loudspeaker
S.E.Xy Speakers | Bottlehead
Old 10th October 2014, 11:12 PM   #3
I'm hungry for a burger...maybe I should eat a ham sandwich first though.
I know you're trying to be helpful, and I do appreciate the links and information, however I really do want to build some horns.
Been there done that. I've built a pair of A25 replicas, a small sound bar format L/R/C setup, and countless subwoofer enclosures (ported, sealed, bandpass, etc).
Agreed, but it's also not my first, but it will by my first horn.
Old 10th October 2014, 11:28 PM   #4
zman01 is offline zman01  Bangladesh
h2oTom,
The FH3 is good. If you want more oomph and want to play louder, then take a look at the Frugal Horn XL.
If you are talking about the Lotus designed by Scottmoose - then that is a BVR (Big Vented Reflex).
Old 10th October 2014, 11:31 PM   #5
frugal-phile(tm)
planet10's Avatar
Originally Posted by h2oTom View Post
Fostex FE166En
The Fostex recommended horns are not among the best.
This driver may work in the Frugel-Horn XL with suitable damping changes -- the guy that installed the FE168eS (which requires similar loading) is happy with them.
Austin A166, Haruna, and Victor are well proven for FE166.
Smaller drivers are better in some ways, larger in other ways.
What kind of amplifier do you have -- it should be noted that these drivers tend to work better with amplifiers that have higher output impedance.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th October 2014, 11:32 PM   #6
frugal-phile(tm)
planet10's Avatar
and not at all suited for FE166
dave
Old 10th October 2014, 11:37 PM   #7
With designs like FH3 or FH-XL there are other drivers out there that can give a "horny" experience.
For Fe166EN Victor would work?
But that's a big one and does it need corners?
IMHO it is better to determine listening goals first, then choose a suitable design (taking into consideration room etc), and then going for the drivers.
Old 10th October 2014, 11:59 PM   #8
Alright, you have the horn fixation. Nothing wrong with that, so just build the ultimate, the Austin. If that's too much work, a BiB.
Old 11th October 2014, 12:13 AM   #9
xrk971 is online now xrk971  United States
xrk971's Avatar
Are you up for front horns too or just BLH's?
Here is a tractrix horn. Presenting the Trynergy - a full range tractrix synergy.
Old 11th October 2014, 12:17 AM   #10
frugal-phile(tm)
planet10's Avatar
Victor was designed specifically for FE166. They certainly needed no corners when i had them in my room.
Woden Design Victor for FE166En
dave
Back to Acoustat 1+1's after 13 years of SET and Horns blgtrio Planars & Exotics 46 7th July 2014 09:33 PM
jbell's set of four tapped horns davygrvy Subwoofers 480 19th March 2014 01:27 PM
How to build large round front horns? Studio Au Multi-Way 77 27th August 2013 12:14 PM
I want to build midbass horns....where to start??? djn Multi-Way 24 1st April 2010 12:34 AM
SET, Push Pull, or T-Amp best to drive Frugel horns? blue lander Full Range 83 17th March 2010 11:55 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
