3D printed supercheap speaker (mono) - diyAudio
Old 10th October 2014, 04:55 PM   #1
NicoMMF is offline NicoMMF  United Kingdom
Default 3D printed supercheap speaker (mono)
Hey guys,
on myminifactory.com, we recently uploaded a printable very cheap speaker:
Download Hex Speaker (Mono) by LeonSingle - MyMiniFactory.com
So right now i must confess that the accoustic of this is not the best, but I was thinking that maybe I could find some enthusiasts on this forum who would want to have a look at it or customize it, maybe try other speakers etc...
Anyway the STL file is available for free so if it can be useful for you in anyway, feel free to download it!
Old 10th October 2014, 05:15 PM   #2
Speakerholic
Cal Weldon's Avatar
I think the problem is at least as much with the driver as the enclosure. It is a very inexpensive unit reminiscent of the days when a transistor radio was a new and wonderous thing.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 10th October 2014, 05:43 PM   #3
Yeah, that is very likely... Is there anything you would recommand but keeping in mind the idea of something quite cheap to produce for any 3D printer owner?
Old 10th October 2014, 05:48 PM   #4
Speakerholic
Cal Weldon's Avatar
Better driver and larger enclosure?
Every driver has what could be considered an ideal enclosure for it. If you want anything resembling bass, you have to allow for the driver to 'breathe'. Some drivers are best in sealed, some vented, some exotic. Just like certain tires are meant for certain cars/trucks and driving conditions.
Old 10th October 2014, 07:21 PM   #5
With only around 1W of clean output and a teeny driver, there's not much you can do. It's debatable whether spending any money at all makes sense without upgrading the amp first - it's a better project for scavenged drivers, maybe.
I happen to have a simulation of Faital 3FE20 saved that works fine when adjusted to a 9.5cm square baffle (but need to double-ish or more the length and add a port hole tuned for 100Hz). Uses a passive filter, image attached. I certainly wouldn't spend that much on a speaker with so little output, but there it is.
In general, avoid making the front shape any closer to a concentric circle around the driver than you have to. A square with a chamfered edge would be better than what you've got there, and maximize the internal volume too.
P.S. You could just put in one of the LM386 guitar amp designs and a guitar jack with the speaker you've got now and call it a day - should work great. I wouldn't be surprised if that already exists in 3D printer land, though.
Old 10th October 2014, 07:43 PM   #6
frugal-phile(tm)
planet10's Avatar
Cal's take is spot on. The speaker driver isnot all that good, and there aremany improvements /changes that couldbe done to the box.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th October 2014, 12:25 AM   #7
xrk971 is offline xrk971  United States
xrk971's Avatar
If one is going to 3d print you want to do something that is basically impossible to make using conventional methods. Like a very complex BLH or TH. Jennygirl asked this question sometime ago as she has her own 3d printer capable of a 24in cube workpiece.
mini 3d printed tapped horn
The thread stalled out but the capability is there.
Old 14th October 2014, 11:47 AM   #8
Oh cool, will have a look at it, thanks!
mini 3d printed tapped horn Jennygirl Subwoofers 25 15th October 2014 02:05 PM
You can now 3D print a speaker JZatopa The Lounge 18 19th December 2013 12:11 AM
USB DAC & headphone Amp with 3D Printed Enclosure Big Gig Headphone Systems 29 6th March 2013 10:10 PM
3D speaker simulator Ptichka Equipment & Tools 0 9th February 2010 07:54 AM
Printed circuit boards for my NaO open baffle speaker. john k... Swap Meet 0 23rd September 2004 11:09 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
