How to clean the Tang Band's sticky shiny rubbery surrounds ?
Old 24th September 2014, 07:12 PM   #1
aarvin2 is offline aarvin2  Mauritius
Default How to clean the Tang Band's sticky shiny rubbery surrounds ?
Hi folks and guys who have Tang Bands, how do you clean the shiny sticky rubbery(it's not sticky or rubbery now as dust got stuck on it) part which is between the surrounds and the cone ?
I'm afraid to use water in case it damages the cone or some other chemical cleaning substance which will eat the rubber.
Is there any chemical substance which repels dust as well and doesn't eat the sticky rubber ?
Thank you Very much for the help
Old 24th September 2014, 07:47 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Try household ammonia on a lint free rag.
planet10 needs your help:
Let's help Ruth and Dave
Old 24th September 2014, 10:31 PM   #3
xrk971 is online now xrk971  United States
xrk971's Avatar
Silicone oil or cyclopentasiloxane should work and be safe on rubber. Same as ingredient in many hair gels and cosmetics. Don't get it on the paper cone though.
Old 24th September 2014, 10:49 PM   #4
Speakerholic
Cal Weldon's Avatar
Ammonium Hydroxide diluted to 50% with water is a cleaning agent used to remove industrial pressure sensitive adhesives. Household ammonia at 5% or so is still very effective in certain situations. The sticky you get on rubber strapped outdoor seating comes clean in a wipe, better than any other cleaner I've tried.
Old 25th September 2014, 12:57 AM   #5
Thank you very much guys guys! Does it stay sticky after you clean it or it modifies the texture ? I have read that it could be some viscous silicone used for damping :O If it's removed it cound negate the effect of the damping :/
Old 26th September 2014, 12:57 AM   #6
ultrakaz is offline ultrakaz  United States
If it is not a coating (sticky gooey stuff) than I would use masking tape or scotch brand tape to remove the dust. And be careful that the tack from the tape is not too strong that it would stretch the surround. I would not use any type of solvent as it may leach onto the cone and or affect the adhesive between the cone and surround. But that is just me.
Old 26th September 2014, 01:52 PM   #7
Squeak is offline Squeak  Denmark
Squeak's Avatar
Weird problem for us such an expensive driver.
My immediate instinct would be to use lukewarm water with a little bit of soap on a Q-tip and try to very gently massage it off.
A little bit of water or water vapor is not likely to permanently damage the paper cone or the surrounds glue, as it is naturally present in the atmosphere at all times to some extent.
Maybe write Tang Band to hear what they have to say about the problem.
Old 27th September 2014, 06:51 AM   #8
maxro is offline maxro  Canada
maxro's Avatar
Cornstarch, applied with a soft brush. This works better as a preventative measure on new drivers, but will also scrub off some dust and cat hair. It will turn the sticky, glossy black to a satiny grey colour.
"No one likes jazz that much; even the guy playing it had to take drugs." -Bart Simpson
How to clean the Tang Band's sticky shiny rubbery surrounds ?Hide this!Advertise here!
Tang Band Tang Band W8Q-1071F 8 X 12 box reccomendation permo Subwoofers 212 4th December 2015 03:15 PM
WTD: Tang Band W3-1878 and Tang Band W4-1337SDF smallangryboy Swap Meet 3 10th September 2013 07:49 PM
How to clean Morel sticky Tweeters gaborbela Multi-Way 21 31st March 2011 03:20 PM
How do you clean a sticky LP soongsc Analogue Source 4 24th June 2005 05:05 PM
Anyone have problems with dust on sticky vintage surrounds? KT Full Range 1 5th May 2005 06:46 PM
Copyright ©1999-2017 diyAudio
