General question regarding Slim Classic GR dCHR-Ken70 1v01 - diyAudio
Old 4th September 2014, 07:21 PM   #1
Fortaz is offline Fortaz  Lithuania
Default General question regarding Slim Classic GR dCHR-Ken70 1v01
Hello,
I have a rather curiousity based question rather then a specific one.
Please see the numbers in the picture: imgur: the simple image sharer
1. How the width of 13mm was calculated for the bracing? How bad would it be to use 15mm? E.g. what is alowed error?
1.1. Just to be sure - is this 13mm width brace should be full depth (246mm), from the front facade to the back?
2. Why is this horizontal bracing (see square no.2) longer than the vertical? E.g. why it does not end like a blue line?
Old 4th September 2014, 07:52 PM   #2
chrisb is online now chrisb  Canada
Originally Posted by Fortaz View Post
Hello,
1. How the width of 13mm was calculated for the bracing? How bad would it be to use 15mm? E.g. what is allowed error?
calculated by the net required port CSA - you would probably suffer no ill effects by using "standard" 1/2" material (could vary from between 12 to 12.7mm)
yes - among other things, adds a little bit of bracing between the 3 connected panels (port slot, bottom and rear panel)
The length and CSA of the port slot(s) determines their tuning frequency - a change to either of the former two will affect the latter.
... so, not as easy at it sounds, this letting go thing
Old 5th September 2014, 05:44 AM   #3
Thank you for the response, Chris.
Just out of curiosity - what kind of problems would I have to deal with, if (in the first question) I would use not 12-12.7mm, but 15mm?
I have the brace that's 15mm, and do not have the propper tools to narrow it down nicely.
Old 5th September 2014, 05:39 PM   #4
Dave is probably the better one to answer that - he normally tries to normalize dimensions to accommodate "standard" material thicknesses - but of course that does vary globally.
As for "proper tools" - I normally just trim material to required dimensions on table saw
Old 5th September 2014, 06:15 PM   #5
frugal-phile(tm)
planet10's Avatar
The vent spacer -- it has nothing to do with the brace -- us set to get the correct cross section area of the vent.
Decreasing the CSA means that the vent is tuned lower. 2mm won't make all that much difference. If you want to be anal you can use this to figure out how much shorter the vent shelf should be to maintain tuning: http://frugal-phile.com/boxlib/Changing-Port-Size.pdf
Originalplans are here: Frugal-phile | Box Library / Mark Audio
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th September 2014, 06:26 PM   #6
frugal-phile(tm)
planet10's Avatar
Yes, the vent spacer should be fill depth
dave
Old 6th September 2014, 10:36 AM   #7
Thank you for the answers, everything is clear now.
Will try to post the pictures soon.
Old 19th October 2015, 07:52 PM   #8
nakki is offline nakki  Finland
Hi, I know this is an old thread but my question fits the title.
What is the designed tuning frequency of the Slim Classic GR dCHR-Ken70 1v01 box?
New Bookshelf Cabinet for Wide & Slim Classic GR dCHR-Ken70 Musik007 Twin Audio 59 18th February 2014 03:44 PM
Alternative drivers and mods for Classic Fonken GR? vincula Full Range 11 25th January 2014 07:42 AM
Wide version of Classic GR dMar-Ken7.3 soren5 Full Range 28 24th April 2013 10:57 PM
Classic Fonken GR MEGA_amp Full Range 5 3rd January 2013 07:38 PM
Classic GR Mar-Ken10.2 2b1 kenix Full Range 7 28th July 2011 02:21 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
