Wharfedale Super 12 RS - diyAudio
Old 28th August 2014, 01:26 PM   #1
Default Wharfedale Super 12 RS
Hi there,
I recently joined this forum after scouring the 'net for information on Wharfedale Super 12 full range drivers, which I purchased recently.
The drivers were not mounted and the seller suggested an open-baffle design. After creating a mock-up I realised that there just isn't enough bass.
Does anyone here have any suggestions with regards to cabinets/mounting solutions?
Many thanks in advance.
Old 28th August 2014, 06:06 PM   #2
Greg B is offline Greg B  United States
You won't get bass with a narrow baffle like that.
Google Briggs open baffle, and you'll find the design for the much wider OB that driver was originally used with.
For any other enclosure suggestions, you would need the thiele/small parameters for that driver, and frankly I don't have a clue what they are.
Old 28th August 2014, 08:50 PM   #3
xrk971 is online now xrk971  United States
xrk971's Avatar
Originally Posted by Schmoove View Post
Hi there,
Add fold back wings to make U channel. That will help bass. Add wing on top edge too otherwise all the bass will cancel on top edge.
Old 28th August 2014, 10:11 PM   #4
sreten is online now sreten  United Kingdom
First check that they don't have the infamous porous
surrounds, that there is no way the surrounds will
pass air, if they do you will never get anywhere.
There are lots of different versions so I can only
roughly only guesstimate a decent box for them.
Placed near the top of a tall and wide but
not deep box that is placed against a wall.
I'd try about 3 cuft sealed and stuffed.
rgds, sreten.
YMMV but i don't have a high regard for
vintage Wharfedale drivers and TBH you
could be engaging on a long pointless
exercise with drivers that are worth
far more than the performance given.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 28th August 2014, 10:29 PM   #5
GM is offline GM  United States
GM's Avatar
The factory cab was a 5 ft^3 damped vent reflex and later a distributed port [damped slotted back] cab and it will also work in the 8.3 ft^3 sand filled panel constructed double slot vented corner reflex [now could be considered a marginal MLTL].
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 29th August 2014, 03:15 PM   #6
Scottmoose's Avatar
Sounds favourite if the space is available. I do like a big box...
Community site www.frugal-horn.com Commercial site www.wodendesign.com
Old 29th August 2014, 09:57 PM   #7
The corner reflex is among my favorite configurations. Actually, somewhere in my junk I have some old David Weems plans for a prism shaped corner reflex for the Super 10.
Old 30th August 2014, 08:21 PM   #8
Scottmoose's Avatar
Probably a reasonable performer. Many were, when tweaked to suit.
Old Today, 12:03 PM   #9
Do any of you happen to have designs that you could share?
Old Today, 03:02 PM   #10
GM's Avatar
Well, I have two different drawings for the 8.3 ft^3 bass cab [Airdale] I listed earlier, just vertically locate the driver where it sounds best to you and of course ignore the drawingís driver cutout dim..
The Ďone size fits allí 5 ft^3 damped reflex cab I donít have a drawing for, but itís basically just a box with a bunch of slots in the back panel [some folks use braced pegboard] with damping material mounted to it, though you would have to test to find the right amount that sounds best to you in room.
Included is two smaller cab designs I forgot I had thatís specific to the 12 RS.
GM
Wharfedale GOLDEN 10 RS/DD DonLuka Full Range 5 22nd August 2012 08:34 AM
Wharfedale W-25 RS Rockaway Subwoofers 5 6th May 2012 07:31 PM
wharfedale super 12 rs dd parameters cone head Multi-Way 1 4th August 2010 04:58 PM
cabinets for Wharfedale 10 RS DD Golden Pat Lindsay Multi-Way 6 19th January 2007 07:48 AM
10inch BRONZE/RS/DD Wharfedale full range drivers SkinnyBoy Multi-Way 0 12th February 2004 04:09 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
