Impressions on Frugal and Maeshowe
Old 24th August 2014, 11:05 PM   #1
FozzZ is offline FozzZ  Canada
Default Impressions on Frugal and Maeshowe
Just looking for listening impressions on the Frugal Horn Mk3 and the Maeshowe. What differences exist and what room recommendations are there.
Using an El70
Old 25th August 2014, 02:09 AM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Been a long time since i have heard both with EL70 -- both have exemplary performance. Maeshowe will have more bass gain (which may well need to be dialed back), the FH3s tapped loading could give the FH3 an edge in mid clarity due to less coming back thru the cone (unless you do a variable depth air cbity in Maeshowe)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th August 2014, 02:49 AM   #3
Thanks for the reply,
I would be making the rear chamber section of the Maestowe adjustable (think diffusor with variable depth). I've had the plans for a few years and have finally put enough time aside to build somthing.
My room is 18'x12'x9' if that alters your opinion?
Because time seems to be a hot commodity, I would rather build the right cabinet the first time. Not that either is wrong
Old 25th August 2014, 03:49 AM   #4
frugal-phile(tm)
planet10's Avatar
You'd be happy with either.
dave
Old 25th August 2014, 04:29 PM   #5
chrisb is offline chrisb
Similarly to Dave, it's been a while since I've heard the Maeshowe, but I think with size of room described, the FH3 might be a far more practical design.
The Maeshowe does produce a big soundstage, and has more LF gain than the FH3 - perhaps more than the EL70 would need in this case. Something like the FE126E would be an entirely different story.
like my mind, this space intentionally blank
Impressions on Frugal and MaeshoweHide this!Advertise here!
Frugel-Horn Sub-Woofer dbailey Full Range 31 28th May 2017 05:52 AM
Alpair 7eN Cabinet Selection (Pensil, BIB or Maeshowe) VFR800A Planet 10 hifi 5 24th March 2011 01:54 AM
A frugal recycled sub idea Brisso57 Subwoofers 15 20th March 2008 08:31 PM
All Frugal loninappleton Full Range 18 5th February 2008 03:00 PM
Frugal sub with old drivers - possible? 38eighteen Subwoofers 16 21st November 2007 10:23 AM
