Alpair7 + Pencil`s stuffing inside
Old 24th August 2014, 01:56 PM   #1
intermantas is offline intermantas  Lithuania
Default Alpair7 + Pencil`s stuffing inside
Please share your experience with stuffing the pencil boxes.
1) Which materials is better - acoustic foam or polly fill?
2) Is it good to use both, like in the picture ?
3) In which place it should be layed out? Where is the critical areas?
4) How amount of filling changes the sound?
5) Which type and size wire could you reccomend for connecting speaker to terminal?
Many thanks
Old 24th August 2014, 05:49 PM   #2
chrisb is offline chrisb
Poly fill- I ended up with rather less than Scott's originally recommended amount ( sorry, I've built several dozen pairs of various designs since those, and can't remember the exact final amount) - I'd trash the foam altogether if I was you
Slightly less dense immediately behind the driver, otherwise my own were fairly even density through out the line.
As for wire, that could start the whole "best?" conversation all over again - my own opinion is that since depending on where you place your input terminals, the internal length of wire could be less than a foot, it hardly matters. Just use the same type and length in each enclosure of course, and I prefer to solder, so something small enough gauge to fold through the small hole on the speaker's terminal.
kinda burnt out - taking a break
Old 24th August 2014, 08:21 PM   #3
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
I have read the foam has some value at higher frequencies that are at issue in quarter-wave pipes, but basically it is useless. Sheep's wool is purported to be the best thing since sliced bread, but does have its own set of problems. Fiberglass is the best material I have found that is readily available. A roll of R-12 will do several speakers.
No, you won't get cancer for the minuscule amount that might escape through the port. You might get silicosis (what killed the Egyptian pharaohs), but that's a stretch.
Bob
Alpair7 + Pencil`s stuffing insideHide this!Advertise here!
Alpair 6 impressions. Question for Alpair7 or Alpair12 owners cangaceiro99 Full Range 22 27th January 2015 04:39 AM
Alpair7/Scanspeak 18WU/8741 Fast markre Full Range 10 18th May 2013 09:02 PM
Kubotech -- Alpair7.3? planet10 Full Range 8 19th October 2012 12:21 AM
TB W5-1611SA vs. MA Alpair7 barackuda Full Range 42 7th February 2011 12:57 AM
Where to place amp: Inside a common cab or inside speakers? goldyrathore Chip Amps 3 3rd September 2010 01:39 PM
