FUll Range with Dayton RS100-8 - diyAudio
Old 15th August 2014, 06:22 AM   #1
prasi is offline prasi  India
Default FUll Range with Dayton RS100-8
Hi All,
I have just simmed a ported speaker with Dayton RS100-8 and the sim is has pretty good frequency response. the box is 5ltr ported tuned to 70 Hz. The FR and X-over are attached herewith for your comments. the design uses two notch filters, one works to tame the BSC as well as bright mids and the other one tames the top octave harshness.
regds
prasi
Last edited by prasi; 15th August 2014 at 06:25 AM. Reason: forgot xover attachment
Old 15th August 2014, 04:42 PM   #2
xrk971 is offline xrk971  United States
xrk971's Avatar
That's a nice response, but a lot of trouble to flatten what should be a flat driver to start with and all those filters drop the sensitivity quite a bit. I suppose there is no getting around the BSC part unless you go with a wallmount, use EQ, or use a cabinet with lots of bass gain more than a BR. You may want to check out the Vifa TC9FD - it is very smooth and flat, about the same size and costs less. Generally, a better performer IMO that the RS100, but it is higher Qts so the cabinet will be bigger. You may want to try the RS100 in a mini Karlsonator - it makes lots of bass and can oftentimes skip the BSC altogether.
Mini Karlsonator (0.53X) with Dual TC9FD's
Another driver worth looking at is the Faital Pro 4FE35, also measures very flat and is 91dB sensitive for about same price or less.
Old 16th August 2014, 01:54 PM   #3
Hi xrk971,
Thanks for the reply. well I will be using these in a home theatre set-up but not at very loud volumes. I agree that all the filters will make sensitivity a bit low. But there are certain issues with the response at 15kHz. I can drop the 10uf-0.64mH-6Ohm notch. But i think the notch for 15kHz is still required, otherwise I will have to listen to the speakers off axis at precise angle which is not ideal. what do you say?..
Old 16th August 2014, 02:11 PM   #4
Bob Brines's Avatar
Remeasure at 15* off axis. I bet that you will not need the top notch.
Bob
Brines Acoustics Web Site
Old 18th August 2014, 06:02 AM   #5
Hi Bob,
Thanks for the reply. I did some web search for the diy using the above driver. In almost all cases people have not used the top octave notch. Just the notch filter to take care of BSC and loud mids. I will do the same.
thanks again
prasi
Old 18th September 2014, 06:39 PM   #6
Default Dayton Rs100-8
Hi xrk971 and Bob,
Here is the design that I came up with after incorporating your suggestions.
Old 18th September 2014, 06:48 PM   #7
here is the sketchup model of the intended full range speaker
Old 20th September 2014, 05:57 AM   #8
hello, can anyone offer comments on the design presented?
thanks and regards,
prasi
Old 20th September 2014, 03:20 PM   #9
Bob Brines's Avatar
OK. What is the hole in the back for? A terminal cup?
Bob
Old 20th September 2014, 03:29 PM   #10
Default RS100 in TABAQ
Hi
I did some sims after been testing the RS100 and found that a modified TABAQ could work well. The last part of the line (the "port") should be increased to set the tuning of the cabinet higher.
I did not try it, however, so it is pure simulation.
Please take a look at my notes.
Hi
Bjærn
FS- Full Range Dayton Audio PS180-8 vdi_nenna Swap Meet 0 12th September 2013 08:43 PM
Air Volume for Dayton RS100-8 4" Reference Full Range Driver Leejin Full Range 14 24th May 2012 07:53 PM
Dayton Audio Neodymium Full Range Drivers form109 Full Range 0 24th October 2010 02:06 AM
Dayton 5" Full Range nige838 Full Range 7 7th April 2010 09:58 PM
FS: (4) Dayton RS100-4s + (1) Dayton RS100-8 Fast1one Swap Meet 4 6th January 2010 11:32 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
