Frugal Horn Mk3 Quick Question - diyAudio
Old 14th August 2014, 09:54 PM   #1
Default Frugal Horn Mk3 Quick Question
I am wondering how these would perform listening nearfield (5 feet) very far away from the back wall? Basically I am using a corner of a basement as my listening room and the speakers are out in the room with my chair 3 feet from the back wall. I do have side walls...kinda....large bookcases...
It's this versus a Fostex BK-12M with a front firing horn - was wondering if this front firing design would be better in this situation.
Just simply wondering how the bass response of a rear firing horn is affected by not having a rear wall to reflect from.
Steve
Old 14th August 2014, 10:25 PM   #2
frugal-phile(tm)
planet10's Avatar
Chris says Pensil.
FH3 with the appropriate driver (not FE126) should work fairly well.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th August 2014, 01:15 AM   #3
chrisb is offline chrisb  Canada
Pensil type MLTL with FF125 was my initial reaction as the cited distance from reinforcing boundaries might be beyond the "goldilocks" range for FE126 in this design and listening position might be too close for the other benefit of the rear mouth (ie wide soundstage spread from early reflections) to integrate with the forward firing output.
OTOH, the FF125wk might work quite well in the FH in this application.
What would be nice to have is a catalog of the number of DIY builds of the design listing the driver makes and models. I know that Dave could compile a list of the 70+ pairs of shipped kits, plus our own several pairs.
As for the BK12 - it's a nice little performer, but I think would deliver better bass extension and "weight" if placed closer to a back wall
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 15th August 2014, 01:35 AM   #4
frugal-phile(tm)
planet10's Avatar
When we 1st auditioned the A7 in FH3 it was a quick swap out and the damping was left optimized for FE126. Even pulled way out from the wall, bass was very tuneful, but could have benefitted from a bit less pf it, FF125 should have the similar "problem"
dave
Old 15th August 2014, 03:10 PM   #5
In the FH, I was initially thinking of the A7 as research points to it being a cleaner driver with lower distortion.
Horn cuttoff quick question esl-fan Multi-Way 2 15th January 2013 01:14 AM
Quick question about bi-amping hi-eff horn ARIYAHOOR Multi-Way 7 17th July 2012 08:20 PM
Frugal-Horn MK3 Google Sketchup Plans DIYampNOOB Full Range 12 19th April 2012 09:06 PM
FOR SALE: Frugal Horns Mk3 with Fostex FE126En Toppsy Swap Meet 5 2nd August 2011 07:23 PM
Single Driver Horn Base Port from Frugal Horn EmergencyDpt Swap Meet 0 26th October 2008 01:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
