how to detach wizzer? - diyAudio
Old 9th August 2014, 02:32 PM   #1
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
Default how to detach wizzer?
how to detach fostex fe207 (no"E")wizzer?
is there more hi-tec methods that stupid cutting?
flesh flash flush
Old 9th August 2014, 02:35 PM   #2
Greg B is offline Greg B  United States
Sure, program your laser cutting machine...
A sharp Xacto or similar hobby knife works fine, just be very careful. I don't recall having any difficulty detaching the whizzer of my old FE164 (no 'E' )
Old 9th August 2014, 04:48 PM   #3
Flaesh's Avatar
laser will cut main cone also
hope Olfa black ultrasharp blade will work
Thak you!
Read somewhere discussion about wizzer detachment using heat gun but not remember results.
flesh flash flush
Old 9th August 2014, 04:49 PM   #4
Thak you!
Read somewhere discussion about wizzer detachment with heat gun but not remember results.
heat gun can help with removing the ring of glue left over.
Old 9th August 2014, 05:47 PM   #5
Flaesh's Avatar
i. e. cut then delet glue, yes?
flesh flash flush
Old 9th August 2014, 05:58 PM   #6
Thak you!
Sure thing! Olfa should be fine. Obviously I was joking about the laser...
I'd be careful with any use of a heat gun. It's easy to get yourself into trouble with those things. (finishes bubble, glue joints separate, etc)
Old 9th August 2014, 06:20 PM   #7
Flaesh's Avatar
make mirror cone equal inner voice coil diameter and apropriate angle.
reflected laser ray must be at least tangent line to main cone at inner edge. voila!..
ok, let glue remaim. I think it neglected up to 1000 hz))
flesh flash flush
Old 9th August 2014, 07:19 PM   #8
that's how i did it yes. then take some very light sandpaper and sand the cone, then treat with enabl or modpodge.
Old 10th August 2014, 12:50 AM   #9
CLS is offline CLS  Taiwan
Why sanding the cone?
Further treating doesn't need any more 'grip' because the (diluted) glue is easily soaking into the paper.
And, would it effectively remove some mass? Hmm....
Be careful to avoid the dust going into magnet gap.
Old 10th August 2014, 01:22 AM   #10
adason is offline adason  United States
adason's Avatar
I do it with great pleasure...
beaming? with a large Full range with wizzer pforeman Full Range 0 10th May 2009 12:34 AM
beaming? with a large Full range with wizzer pforeman Full Range 0 10th May 2009 12:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
