did I damage my FF165WKs? - diyAudio
Old 29th July 2014, 07:02 AM   #1
tilroh is offline tilroh  Australia
Angry did I damage my FF165WKs?
I've noticed a crackle in both my FF165WK MTLTs. I've swapped sources and amps still there's a "ti" sound that accentuates some female vocals and percussion like snare drums. The "tick" sound is barely detectable on most tunes but it makes others unlistenable.
At first I thought I was listening to a FLAC of a scratchy album.
I can push the cones and nothing hits so the problem isn't mechanical.
A EL34 SET powers the speakers. (8-10 w/ch)
As you can imagine this is highly troubling, I'm losing sleep.
Is there anything I can check??
Thanks, Mack
Old 29th July 2014, 10:36 AM   #2
Squeak is offline Squeak  Denmark
Squeak's Avatar
Try to get it to do the thing reliably. Maybe with the frequency sweep and then hold the offending frequency, then you will have a better chance at determining exactly where the fault is by listening with your ear to the cone.
It might just be your cabinet or some loose material in it.
Also try with a difference amp or source.
Old 29th July 2014, 11:17 AM   #3
Thanks, have tried one laptop running Daphile w/LiTe AH dac and another laptop running Win7 & FooBar2000 w/HiFime Sabre U2 dac. Also Trends 10 amp.
A frequency sweep is an excellent idea. I'll try that tomorrow night.
Mack
Old 29th July 2014, 03:16 PM   #4
Speakerholic
Cal Weldon's Avatar
Are your tinsel leads at the bottom of the driver?
planet10 needs your help:
Let's help Ruth and Dave
Old 29th July 2014, 05:48 PM   #5
frugal-phile(tm)
planet10's Avatar
Are the screws too tight? And you should see if the noise exists with drivers removed from cabinet.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th July 2014, 10:47 PM   #6
dave
"Too tight"? I never thought of that. I'll check tonight, thanks!
Old 30th July 2014, 11:16 AM   #7
I removed the drivers, they sure sound different out of the boxes, but pop is still there.
Ran a Sweep and heard no ticks or pops. I paused the player for a while, no music, no pops.
I even tidied my wiring best I could. Still the electrical sounding "ti" is there.
I powered my XMOS spdif converter from USB then a wall wart, same noise.
The distortion seems to happen when certain sounds are produced by the music.
Arrg, Mack
Old 30th July 2014, 04:14 PM   #8
chrisb is offline chrisb  Canada
To completely isolate the problem, have you tried them (either naked or in enclosures) in an entirely different system - i.e. a buddy's home theatre rig?
on hiatus
Old 30th July 2014, 06:26 PM   #9
Coen is offline Coen  Netherlands
Are you sure it isnīt just in the music itself, can you hook up some reference speakers to your amp to compare?
Old 30th July 2014, 07:25 PM   #10
xrk971 is offline xrk971  United States
xrk971's Avatar
Do you have to play it loud to hear the 'ti' sound? Is that a teee (short) sound or a tye (long) sound? Do 's' sounds sound OK, and does it happen more with piano strikes more than other notes?
is this damage terminal busterno1 Multi-Way 11 17th July 2014 07:07 AM
water damage timwebb Car Audio 5 5th July 2010 03:09 AM
I think i finally did some damage Deagle50ae Multi-Way 1 18th April 2005 05:26 AM
Damage recovery Reklats Chip Amps 1 31st March 2005 02:42 AM
damage the laser? maya1 Digital Source 0 16th June 2004 06:09 PM
Copyright Đ1999-2017 diyAudio
