Alpair 10P 'hybrid' build - diyAudio
Home Forums Rules Articles The diyAudio Store Gallery Wiki Blogs Register Donations FAQ Calendar Community
Old Yesterday, 04:46 PM   #1
Bill poster's Avatar
Default Alpair 10P 'hybrid' build
Finally started this build yesterday; all wood cut and ready to trim, do the driver cut outs and assemble cabs tomorrow
H88 x D27 x W18.5 (cm) with a 7 degree lean
The cabs are an experimental folded line type with a rear exit. Internal line length is approx 155 cm, lined with Bawotumex
Old Yesterday, 07:00 PM   #2
zman01 is offline zman01  Bangladesh
Interesting project - keep us posted.
Any design goals in terms of F3 or F10 you can share?
Old Yesterday, 08:07 PM   #3
An f3 in the 40's would make me happy, altho the line is slightly under optimum length perhaps
I guess the goals are adding more bass impact, keeping the response reasonably flat and preserving the good sensitivity of the driver
Old Today, 06:19 AM   #4
The first point - more škickš in the bass if I understand correctly? Not a bad goal to have, especially since it is a relative weak spot for many wide-band designs.
Old Today, 07:58 AM   #5
Most Alpair drivers have a natural rise to compensate for baffle step, the 10P less so. But off-axis seems to level off the lower treble and the response above 10khz still looks ok.
Hopefully the cabinet design works ok too
Old Today, 07:33 PM   #6
Bare is offline Bare  Canada
Interesting build.. I'm considering this driver for a project as well.
What is the actual Cone diameter.. If you might?.
Asking because I've noticed that Mark Audio has an annoying habit of giving the inner edge of the Mount ring as Nominal diameter. Never the actual piston /cone dimension.
Piston cone /area is a significant spec.. in my observations
Old Today, 07:39 PM   #7
chrisb is offline chrisb  Canada
Are these published specs insufficient?
T/S Anechoic: 2.2/30g spider final version: 10P Gen.1
Revc= 6.200 Ohm
Fo= 42.398 Hz
Sd= 88.250 cm
Vas= 29.995 Ltr
Cms= 2.712m M/N
Mmd= 4.719 g
Mms= 5.196 g
BL= 4.741 TM
Qms= 2.425
Qes= 0.382
Qts= 0.330
Levc= 50.196u H
No= 0.579 %
SPLo= 89.645 dB
Xmax = 7mm (1 way) limited by Arrestor
Power = 30 watts Nom.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old Today, 07:58 PM   #8
Bob Brines's Avatar
Originally Posted by Bare View Post
....I've noticed that Mark Audio has an annoying habit of giving the inner edge of the Mount ring as Nominal diameter. Never the actual piston /cone
Madisound has the annoying habit of assigning MA drivers to a size class based on frame size. Mark names his drivers by the cone diameter. The cone of the A10P is 10cm in diameter. Of course, the Sd is on the spec sheet, and that is the number you really want.
Bob
Brines Acoustics Web Site
Old Today, 08:04 PM   #9
frugal-phile(tm)
planet10's Avatar
The number in the name is very close to the actual cone diameter, in cm for the Alpairs, in mm for the lower end line.
dave
Edit: Bob beat me.
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Enclosures for Alpair 10p Philosophil Full Range 24 24th June 2014 07:32 PM
Alpair 10P: Preview markaudio Markaudio 272 23rd April 2014 03:22 PM
Alpair 10P vs A12P kinku Markaudio 122 21st March 2014 02:25 AM
Pensils for Alpair 10.3 & Alpair 10p planet10 Markaudio 66 31st January 2014 05:52 AM
Need advice for Alpair 10p build a3cervo Markaudio 40 21st December 2013 03:04 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
