I may want to use the widely-recommended TB W3-871S wide-range drivers in a future multimedia speaker project. The problem is that its T/S parameters are somewhat odd. If I use a sealed box with the normal Q of 0.707, the "optimum" volume is a large 16.7 L (0.59 cubic ft.) I'm leaning towards the acoustic suspension box as opposed to the bass reflex, but if either can be made small enough (<3 L or 0.10 cubic feet) and be optimum, I can accept it. I realize that there are DIY projects on the web using the W3-871, but which one is "optimum"?
If it can be made to fit in a 8.5"x5"x6" (hwd) box and be near optimum, that'd be great! BTW would it be wise to power the 30-watt-max TBs with 40-watt-per-channel (RMS) amplifiers just for sheer headroom? Thanks for any advice. |
#2 |
The single driver Elf 1.0 from CSS uses a vented box that's 6.5"x7.5"x6.25" external. Also, check this design.
John R's TBand |
#3 |
I want to focus on a sealed box just for the sake of simplicity. With a system Q of 0.707, the internal enclosure volume for the W3-81S is about 3.8 L (0.135 cubic feet), which is a little too big for me. I understand that the 871 doesn't have a very good Xmax, and too small a box can lead to it reaching the excursion limit.
Has anyone used the 871's in higher-Q (i.e. smaller) boxes? Is 0.8 acceptable? BTW the enclosure sizes I gave earlier were based on incorrect specs given by Creative Sound Solutions (CSS) of Canada, not from TB. Someone should tell them...
KTK. Kool To the Kore. |
#4 | |
My girlfriend's sub is bigger than mine...
#5 | |
Do you happen to know how many units CSS tested to obtain this info?
#6 |
hey, i just finished building a set of speakers based off of that link. i built the taller ones and they are farely close to your .707 (i think its around .72). i just started auditioning them about 20 min ago and very impressed so far. i understand there will be little to no bass from these, but mated with a small sub, they sound very nice (might run off of my creative/cambridge soundworks 4.1 pc system for the time being. gotta find out the stock speaker's ohms). here's a pic.
#7 |
a better one...
#8 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 |
==== Using measured specs and somewhat less simplified formulas I get 0.95ft^3. ==== >I'm leaning towards the acoustic suspension box as opposed to the bass reflex, but if either can be made small enough (<3 L or 0.10 cubic feet) and be optimum, I can accept it. I realize that there are DIY projects on the web using the W3-871, but which one is "optimum"? ==== 'Optimum' depends on what the app. is, and in your case, the smallest I recommend is a 0.8Qtc with a 2nd order XO at 500hz or 4th at 250Hz to realize all of what little dynamic headroom the driver's capable of. 0.14ft^3 plus driver, then reduce actual Vb to 0.8x and stuff it with 1.0lb/ft^3. Unfortunately, this doesn't meet your size criteria, so build it the size you want and accept whatever performance you get. ==== >BTW would it be wise to power the 30-watt-max TBs with 40-watt-per-channel (RMS) amplifiers just for sheer headroom? ==== It's always better to have too much power (within reason) than not have it and clip the amp and either have it sound compressed and/or damage the driver. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#10 |
When looking at John's TB site how would his designs change if I wanted to add 2 speakers per box, or more? Would the Filter values change? I would like to build a center channel with the W3-871's. Thanks
| WTB a Tang Band 871S | joeybutts | Swap Meet | 14 | 19th November 2009 04:56 PM |
| Fs: Tang Band W3-871s drivers | norman bates | Swap Meet | 17 | 13th November 2008 09:44 AM |
| I want your tang band w3-871s !!!!!!! | norman bates | Full Range | 0 | 15th September 2008 06:43 AM |
| FS: Tang Band 871s | jmikes | Swap Meet | 1 | 21st March 2007 03:34 AM |
| Tang Band W3-871S with KEF B139 | anannra | Multi-Way | 2 | 14th January 2004 10:11 PM |
| Page generated in 0.12454 seconds (80.84% PHP - 19.16% MySQL) with 11 queries |
