Rope coil baskets as enclosures? - diyAudio
Old 13th July 2014, 03:25 AM   #1
Soldermizer's Avatar
Default Rope coil baskets as enclosures?
Been reading up on old foam core threads and I was struck by a (possibly) innovative idea:
If one wants to build an unusually shaped enclosure (such as the cones, horns or other curvy and carpentry-resistant shapes found on exotic desgns) why couldn't one...
Use a coil of rope? Just Google "rope coil basket" or "rope basket" and especially in photos, you'll see that it is a widely used medium for making, well, baskets out of rope, yarn, etc.
Why couldn't one make a 3-D shape that would be what's needed for a weird design? For example one of the B&W (?) teardrop aperiodic enclosures for the mids, highs?
Possible advantages: materials are cheap: probably can do it with rope and glue, including xrk971's all-time favorite, hot melt glue! You could create most any shape as long as it is a spiral laid out design. Sort of how a dog um -- extrudes his grotesque bowel sculpture -- but would be laid down and glued as you go. Fibers are naturally sound absorbing which is usually desirable. High decoration possibilities. If you have a crafty wife or other talented person (especially at a low wage scale) she can make something artistic to absorb that nasty backwave. Yes, some females have a predilection to almost pathologically knit most all the time, much akin to how certain males make DIY speakers. My proposal would harness the female's innate nesting insinct towards audio ends. Heck, maybe even knit a set of speakers?
Challenges: not by nature air-tight. No problem. Inside, outside, or both are covered in more glue, paint, resin, whatever to make it sealed. Probably time consuming. Difficult to undo a mistake.
P.S. I claim dibs on "knotaloss" for a project name I look forward to being upbraided by you for my knotty ideas. You must admit, though, I have struck a cord.
Sincerely, your basket case, Soldermizer.
Don't worry what other people think. They don't do it very often. Hey! I said "Think for yourself!!!"
Old 13th July 2014, 05:16 AM   #2
Speakerholic
Cal Weldon's Avatar
Stop asking and just do it. Your understanding of the fairer sex is outstanding. I wish I had your stones, not to mention the extremely punny way of looking at things.
It might actually work if you use a high q driver, and the pics of the project would be great. Let's see something by next Saturday.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 13th July 2014, 11:53 AM   #3
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Enclosures in principle should be rigid and airtight; the basket fails on both counts.
You´ll reinforce it with hot glue?
Poor choice and expensive, once you add up the hundred or more stick cost.
Better mix some marine grade (which actually is the cheapest and most available) polyester resin and brush it on, layer after later.
Fiberglass improves the end product.
In fact, forget the basket and make your reinforced resin cabinet in any shape you wish, since that seems to be the point.
Knit damping material? What for? It won´t absorb more or better than before.
Old 13th July 2014, 12:28 PM   #4
xrk971 is online now xrk971  United States
xrk971's Avatar
Interesting idea there Soldermizer. You are on the right track and if you recall, Patrick Bateman has been making custom odd shape horns to, pardon the pun, shoehorn into the crevices of the door panels of his car for years using burlap and PVA glue. Sisal rope, burlap bags, etc can all be used with whatever hardening matrix agent you wish. The cheapest of which I would guess is flour and water for a burlap mâché horn. The structure can then be painted with waterproof sealer once done. I am with Cal, just go do it and show us some pics by next week! There are premade basket material sun hats that may make a good fullrange tractrix horn once hardened with PVA.
X
Old 14th July 2014, 02:26 PM   #5
the rope might provide a nice aperiodic enclosure though most rope is tight but the fibers will provide a lot of internal loss. Good idea now you need to make it work. Best regards Moray James.
moray james
Old 14th July 2014, 03:09 PM   #6
how about forming the shape using rope first, then cover both sides with cement.....
fiber-reinforced concrete-enclosure.
Old 14th July 2014, 03:54 PM   #7
Bare is offline Bare  Canada
Why Dick around with bits of hairy rope?
A favourite Crazy old Gardening lady standby: Hypertufa.
How to Make Hypertufa Planters: 8 Steps (with Pictures) - wikiHow
Easily done, decidedly rigid and can always be recycled as a plant pot
I love rope caulk. Cerwin D7's are better now! TMHutson Multi-Way 16 21st July 2014 09:18 PM
A round-up on successful enclosures for Coral Holey Baskets Brisso57 Full Range 0 5th July 2014 12:08 PM
subwoofer baskets Clipped Car Audio 5 17th February 2009 06:31 PM
Mortite/Rope Caulk for Cabinet Deadening sdclc126 Multi-Way 37 8th June 2006 11:38 PM
Using rope caulk (mortite) to seal drivers and damp vibrations percy Car Audio 0 31st July 2005 03:16 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
