Speaker ID (Philips?) - diyAudio
Old 6th July 2014, 05:04 AM   #1
rb1234 is offline rb1234  New Zealand
Default Speaker ID (Philips?)
Hi all,
A friend has given me two old speakers that both have the following on them:
2422 257 51104
AD 12252/HP8
DD 00 609 111
Made in Belgium
From what I've read online these are probably Philips. I am interested in using them as outputs for a 100w guitar amplifier that requires a min. total impedance of 4ohms and two speaker outputs. I'm hoping someone here can help me figure out what the impedance and watts for these speakers are before I hook them up.
P.S. these speakers were given to me with two tweeters also. I'm not sure if these were originally paired with the other speakers but i'll probably exclude them if I use these for my guitar amp. I assume the impedance/watts will still be appropriate?
Thanks in advance for any help / ideas
Old 6th July 2014, 05:26 AM   #2
frugal-phile(tm)
planet10's Avatar
It is a Philips. 12" 8 ohm.
Pictures?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th July 2014, 02:41 PM   #3
IG81 is offline IG81  Canada
IG81's Avatar
http://ldsound.ru/wp-content/uploads...ldsound_ru.pdf
Check at the bottom of page 3. No T/S parameters, but a bit of detail. IMO, the 'HP' suffix may simply mean high-power and can be found in both woofers and fullrange units, respectively with W and M suffix, followed by the impedance as P10 noted.
Seems like they built a stiffer suspension for it, increasing excursion-limited SPL up, or closer to its thermal limits and the resonant frequency at the same time.
EDIT - The legend for Philips part # is on page 9 of the linked document. HP does stand for High-Power as I had guessed. I suppose this would make this driver about as suitable as any Philips can be for guitar, but it is still a music/hi-fi unit.
Philips CD620 DRAM Chip ID help please! James1 Digital Source 2 13th September 2010 06:28 PM
B+W Speaker ID Please thermionic Multi-Way 2 30th October 2009 06:05 PM
driver id./info for Isophon/Philips/Fisher(Marsland?) Kazik Multi-Way 1 11th March 2007 03:45 AM
Speaker ID ddoyle Multi-Way 1 28th April 2006 03:08 PM
KEF speaker ID... bibster Multi-Way 9 30th August 2004 09:09 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
