I'd like to know what the recommended wire routing is from the driver to the terminal cup is. Does one simply wire direct from point to point, or should a hole be drilled through the internal baffles and the wires pulled through to the terminals? Apologies in advance for the noob question.
Thanks,
Jeff
Thanks,
Jeff
