Someone know a good fullrange PA design ?
Old 16th January 2004, 10:15 PM   #41
Bull is offline Bull  United Kingdom
Default reply
Put 4 [castors'wheels' with locking brake] on the bottom of the scoop bass bin and two metal bar handles or spring loaded handles at the back and pull it along,but watch your toes.
Yes I ran over my toes with a speaker once,so I bought steel toe cap boots to protect my feet when transport the big scoops and 12 u flight rack on castors.
And also you can't use any 15 inch, but if you don't want to measure enclosure volume then make sure the driver has these specs: QTS of 30 or less,BL product of 14 or higher[Motor Strength],EPB [Efficentcy Bandwidth Product] of 100 or higher,
X max doesn't matter as much,since horn loaded bass bins work like a piston.
And the driver has to have a magnet 50 oz or bigger, 2.5 inch voice coil or bigger.
Die Cast Aluminium frame is better than pressed steel frame because it's stronger,cools the voice coil better,and concentrates more magnetic field into the pole piece.
Someone know a good fullrange PA design ?Hide this!Advertise here!
OTL AMPLIFIER AND FULLRANGE DRIVER : a good match ? hornophile Full Range 4 24th September 2008 11:35 PM
Fullrange/TML/Good efficiency AudioAngel Multi-Way 1 12th April 2005 06:55 PM
fullrange, compact and good bass possible? axebeatz Full Range 11 27th January 2005 08:46 PM
fullrange driver for a 3-way, good option ? mbon Multi-Way 2 13th June 2004 08:39 AM
Copyright ©1999-2017 diyAudio
