Someone know a good fullrange PA design ?
Old 9th January 2004, 06:18 PM   #11
OMNIFEX is offline OMNIFEX  Jamaica
OMNIFEX's Avatar
Rog is a Good Friend of mine! As a matter of fact,
Rog was the first person to really explain to me, how bass
horns and the right woofer (TS Parameters) works hand
and hand. A next man I have to credit to is Weoggo Reed,
Ihoan (Designer of Bassmaxx) and, Bill Fitz _ _ _ _ ?
I've been friends with Rog before he put up that site.
If you look closely, most of those boxes are designed with
Precision Devices Speakers in mind.
If you have access to those speakers, build the PD 1850
Horn!
I can't imagine why you need to build one bass horn, but,
you seemed determined, so the most I can tell you is to
give it a shot!
If it doesn't give you the sound you want, just build another
one.
OMNIFEX
Old 9th January 2004, 06:49 PM   #12
darkm4n is offline darkm4n  Romania
darkm4n's Avatar
Send a message via ICQ to darkm4n Send a message via MSN to darkm4n Send a message via Yahoo to darkm4n
Hmm.. you have interesting friend's ...
I don't really have access to those speaker's ... but i can search and maybe find one , but , if i use other speaker ? 15 " one ?
senon PA1270 i guess .. i can get it for free .. what the result's will be ?
Old 9th January 2004, 07:00 PM   #13
OMNIFEX's Avatar
To be honest,
I've never heard of that speaker before, and, have no clue
what the TS Parameters are.
If you're going to build a 15 horn, maybe you should try
the HD 15. Providing that free speaker meets the horns
requirements
If its a unknown driver, (No TS Parameters) the only thing
I can recomend is throwing it in a sealed box.
I Just want to say one thing........ If you are under budget
constraints, maybe you should hold off on building a bass
horn.
Buiding bass horns are not exactly a walk in the park
(So to speak) You will spend alot of time, and
money on this project.
OMNIFEX
Old 9th January 2004, 07:26 PM   #14
darkm4n's Avatar
Magnet weight: 850oz
Voice Coil: 2.5"
Max.Power: 350W
Frequency Response: 30-3.5KHz
Sensitivity(1W/1M): 93dB
This is what i know about this driver ...
I don't know .. HD15 look very fine to me .. and not very expensive ..
Do you think that i should build that ?
Old 9th January 2004, 08:06 PM   #15
darkm4n's Avatar
Yes ... i gonna build the HD15 .. but i'am still waiting for you advice ..............
Old 9th January 2004, 08:56 PM   #16
darkm4n's Avatar
Hmm ... i know that the box of a speaker is the most important .. that's way i want to make it good ..
What about this Ts ?? What is that ?
The HD1850 with that driver could sound like crap , what about the HD15 ?
I have experience in building cabinet's .. but i don't have in design ...
I don't want such a low freq. bin .. just one with a firm kick ... i inted to use it in live application in romania ( over 100 people ) outside .. so .. what do you think is the best ... i all ready have 2 bin's ( 4 driver's ) multirange .. and 2 bass tube's ( like the car one's ) and i can't get the sound i want .. not enoth bass/mid i guess ... and not enoth power ...
Thank's !!!!!!!
Old 9th January 2004, 09:55 PM   #17
OMNIFEX's Avatar
Dude, don't take this the wrong way...................
If you are not going to invest in the right tools
to get the job done right, you should just scrap the idea.
Either build the HD 15, or PD 1850 with the speakers
Rog recomended on the site, or don't build it at all. As
far as I remember, he offered alternative speakers that
will work in either cabinet. They may not be as efficent
as the Precision Devices, but they will get the job done.
You mean to tell me you can't buy any one of the
alternative speakers he recomended?
The speaker you want to use will not do the job in
those boxes. You'll end up wasting your time and
money, and be highly upset in the long run. Buy the
right speakers, or use those "Free Speakers" and build
a Double Fifteen box.
Period.
Again, don't take this the wrong way. I'm just being
to the point about things.
Remember,
There Are No Shortcuts In Audio.
Oh!
The TS Parameters are tools that helps you determine
what kind of box the speaker will give an optimum
response.
For example; Fs, Re, Qes, Qms, Qts, Xmax, and so forth.
Beside each one of those abriviations, should be numbers.
Surely, you used a speaker design program when you
built those other speakers right?
Best Regards,
OMNIFEX
Old 10th January 2004, 06:50 AM   #18
darkm4n's Avatar
About the tool's .. i have all the tool's you can imagine ... from a driller to osciloscoope's , about the wood .. i get it for free ....
Yes , someone calculate my last speaker , they have about 104 dB and 36 Hz . As my amp's .. most of them are build by me .. for the horn's ( if i gonna build them ) i'll use a 2 x 800 W , useing 24 output transistor's ...
If i gonna find the right driver's i think i'll build the HD15 .. it's smaller ...
What speaker software do you recomand me ?
Old 10th January 2004, 07:15 AM   #19
darkm4n's Avatar
Hmm...
What about that box with 2 driver's ( 15" ) that you mention ?
It's a simple cabinet design ?
If i gonna put an Eminence Kappa 15LF in the PD1850 horn will sound good ? He dosn't mention alternative drivers... ( name's .. only some specs about the driver i should use )
From a PD15 Horn with Eminence Kappa 15LF and a W bin with the same driver what you will chose ? I'am telling you that because in this morning i visit a friend that haved 4 x Wbin's and it sound great .. all the room shakeing ... he gave me the plan .. it's a ordinary plan from the net .......
Old 10th January 2004, 02:50 PM   #20
OMNIFEX's Avatar
I got a gig to do.
I'll answer your questions Sunday night.
Enjoy Your Weekend!
OMNIFEX
Someone know a good fullrange PA design ?Hide this!Advertise here!
OTL AMPLIFIER AND FULLRANGE DRIVER : a good match ? hornophile Full Range 4 24th September 2008 10:35 PM
Fullrange/TML/Good efficiency AudioAngel Multi-Way 1 12th April 2005 05:55 PM
fullrange, compact and good bass possible? axebeatz Full Range 11 27th January 2005 07:46 PM
fullrange driver for a 3-way, good option ? mbon Multi-Way 2 13th June 2004 07:39 AM
Copyright ©1999-2017 diyAudio
