Old 19th August 2014, 05:17 PM   #21
mrneedle is offline mrneedle  Netherlands
Hi everyone,
It's been a few months... but I'm still thinking on how to put these 5" drivers to use... Would it be possible to use the 4" & 5" together?
use the 4" for the higher frets & 5" for lower freqs inside the cab I've build for the 4 inch?
(the 5" would be mounted on the side) or is this just a bad idea I should forget asap?
here is the 4" cab.
Old 19th August 2014, 11:58 PM   #22
jonnoshore is offline jonnoshore  United Kingdom
The 5 looks more open at the back.... Thought about trying it in open baffle?
John
Old 22nd August 2014, 07:45 PM   #23
something like this?
Old 22nd August 2014, 10:55 PM   #24
Would that work?
John
Old 10th September 2014, 09:06 PM   #25
wouldn't the back loaded horn described in the Fostex FE166ES R manual be an option?
http://www.madisound.com/pdf/fostexcabs/fe166esr.pdf
Old 11th September 2014, 06:52 AM   #26
talaerts is offline talaerts  Belgium
Almost certainly not. For it work your 5" driver should at least have a Qts that is similar to the ESR, and in reality it is very different.
I remember that someone recommended a TL in an early post dedicated for your 5" driver. Much more sensible to use a dedicated design.
Old 11th September 2014, 07:30 AM   #27
freddi is offline freddi  United States
freddi's Avatar
the 5 looks like it would work in a scaled "Karlsonator" - ask XRK971 what scaling fits. Greg B. created 3 official sizes - 6", 8" and 12" - those in the mini thread are scaled from the 12" model.
Old 11th September 2014, 02:56 PM   #28
Well that's true, someone was kind enough to do the math for a TL. I still think this would be an option although a bit big according to the WAF, but I'd like to try and to do it myself.
I bought the MJK math cad sheets, but that's just not my cup of tea...
but I found the leonardaudio.co.uk TL software this morning. I did have a quick look but I couldn't find the correct data provided by the manufacturer for Sd and Lvc.
Sd=?
Qes=0.539
Qms=10.5
Lvc=?
Re=6.8 Ohm
Fs=59.5Hz
Vas=15.47Ltr = 0.01547m3
Old 11th September 2014, 05:30 PM   #29
methodarn is offline methodarn  Russian Federation
Location: Moscow, Russia. Hope someday I find warmer place :)
just receive Aucharm speakers, they looks like audio nirvana, but cone from different material. higher distortion and lost of dynamics, AN better at all
Old 13th September 2014, 04:17 AM   #30
ttan98 is offline ttan98  Australia
I adapter this driver as an OB similar to SL, LXMini speaker configuration. I thought guys maybe interested, anyway this driver sounds great you will not be disappointed.
Chinese/Taiwan 4 Dual Cone Speakers stoodood Full Range 208 25th October 2015 10:51 PM
Just found a good deal on 5.25 Dual Cone 20 Watt Speakers Michael Bean Full Range 13 10th July 2014 10:59 PM
FS: Kenwood KFC-16595 dual cone speakers (Australia) Brisso57 Swap Meet 0 1st January 2008 12:53 PM
KLH dual cone speakers specs MPM Full Range 0 25th August 2005 03:35 PM
Dual Cone drivers and Line Arrays fr0st Multi-Way 7 3rd November 2004 09:28 AM
