Hi everyone,
It's been a few months... but I'm still thinking on how to put these 5" drivers to use... Would it be possible to use the 4" & 5" together?
use the 4" for the higher frets & 5" for lower freqs inside the cab I've build for the 4 inch?
(the 5" would be mounted on the side) or is this just a bad idea I should forget asap?
here is the 4" cab.
here is the 4" cab.
The 5 looks more open at the back.... Thought about trying it in open baffle?
something like this?
wouldn't the back loaded horn described in the Fostex FE166ES R manual be an option?
http://www.madisound.com/pdf/fostexcabs/fe166esr.pdf
Almost certainly not. For it work your 5" driver should at least have a Qts that is similar to the ESR, and in reality it is very different.
I remember that someone recommended a TL in an early post dedicated for your 5" driver. Much more sensible to use a dedicated design.
the 5 looks like it would work in a scaled "Karlsonator" - ask XRK971 what scaling fits. Greg B. created 3 official sizes - 6", 8" and 12" - those in the mini thread are scaled from the 12" model.
Well that's true, someone was kind enough to do the math for a TL. I still think this would be an option although a bit big according to the WAF, but I'd like to try and to do it myself.
I bought the MJK math cad sheets, but that's just not my cup of tea...
but I found the leonardaudio.co.uk TL software this morning. I did have a quick look but I couldn't find the correct data provided by the manufacturer for Sd and Lvc.
Sd=?
Qes=0.539
Qms=10.5
Lvc=?
Re=6.8 Ohm
Fs=59.5Hz
Vas=15.47Ltr = 0.01547m3
just receive Aucharm speakers, they looks like audio nirvana, but cone from different material. higher distortion and lost of dynamics, AN better at all
I adapter this driver as an OB similar to SL, LXMini speaker configuration. I thought guys maybe interested, anyway this driver sounds great you will not be disappointed.
thanks for your reply, sure it does look interesting and very small! i've found the thread about the "LXmini" but am still stuck at terminology here...
what is an OB, SL?
would you mind sharing dimensions and circuits?
OB - open baffle, SL - S. Linkwitz go to his website, do a search you can locate his website very easily, at this sit look for LXMini speakers plenty of info there.thanks for your reply, sure it does look interesting and very small! i've found the thread about the "LXmini" but am still stuck at terminology here...
what is an OB, SL?
You can design your very own speakers based on this speakers config., you must have speakers measuring instrumentations and digital xcover. I don't think it very difficult to design and very easy to build. Overall this type of speakers sounds really good. FYI I have built many speakers before incl. conventional spks and open baffle spkrs, etc. Overall a worthwhile exercise.
Ebay listings change but you can always search for user davidlouis or google davidlouis audio 2pcs pair DAVIDLOUIS AUDIO HiEND 5 inch full range fullrange speaker PK fostex | eBay
Thanks! Found the USD site: pair 2pcs HiEND 6.5inch fullrange DIATONE P610 CL0N upgrade version ,better 50 items in Anita HIFI Shop store on eBay!
GM
GM
Anyone know anything about these?
Pair 2pcs Alnico HiEnd 8inch Fullrange Speaker Driver Defy Lowther Fostex | eBay
GM
GM
- Full Range
- Chinese/Taiwan 5” Dual Cone Speakers
