Stick cabinet construction - diyAudio
Old 9th May 2014, 07:07 AM   #1
Default Stick cabinet construction
Had an idea last night, but I've never seen it done like this (in my limited experience of speaker building).
Having seen stacked pieces assembled to form a cabinet, most notably "The Two Towers" The making of: The Two Towers (a 25 driver Full Range line array)
I was wondering about building stacking sticks from front to back, as opposed to stacking from bottom to top. Then, the outside could be sanded smooth, and the inside would stay irregular.
Kinda like this:
Old 9th May 2014, 08:09 AM   #2
HENK021 is offline HENK021  Sweden
Send a message via MSN to HENK021
it would probably work, but keep in mind that wood is constantly moving and it will dry unevenly, making it difficuult to get a good result. Best is be to use really really dry wood when making the cabinet
I have made a wooden curved cabinet using birch wood. I glued together pieces making a board, then i made groves on the inside (like the MDFboard thats bendable). It tured out pretty good, but still after 7 years the wood is moving and changing a little bit. The top and bottom of the speaker is design so it lets the wood move without creating cracks.
I can try to look up some pictures of the design.
Speaker cabinet construction Q erica1212 Construction Tips 7 5th December 2013 11:26 PM
Cabinet Construction stolenband Instruments and Amps 1 9th March 2011 06:25 AM
New cabinet under construction. Andy G Multi-Way 42 23rd June 2008 06:43 AM
Some more info on cabinet construction Yesfan70 Full Range 16 5th May 2005 04:17 PM
cabinet construction tenderland Full Range 16 9th January 2005 02:52 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
