Where to start?! - diyAudio
Old 8th May 2014, 04:47 AM   #1
kr1s is offline kr1s  United Kingdom
Default Where to start?!
Hi All
I've been lurking here for a little while but this is my first post so please go easy on me!
I'm feeling the urge to build myself a nice set of speakers but am not sure which design or driver to go for.
My room is 6m x 4m x 2.6m
My musical taste covers classic rock, indie rock, folk rock and only occasional acoustic or classical.
I tend to like big speakers with a warm sound (not least because a lot of what I listen to isn't so well recorded and can sound harsh). Currently I have Naim Intro which I like a lot.
They will be driven by a Yaqin MC-300C amp which is only 8W/ch so I'll need quite high sensitivity.
My budget is around 500.
I can do woodwork but am not an expert and don't have access to CNC machinery so I will either need to hand cut or use pre-cut panels.
From what I've read, I've considered the Frugal Horn 3 but wonder whether it will give enough bass for my liking, so maybe one of the Pensil series with the larger drivers would suit better?
Any guidance gratefully accepted!
Chris
Old 8th May 2014, 04:50 AM   #2
frugal-phile(tm)
planet10's Avatar
For your needs you might better consider Frugel-Horn XL with A10p.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th May 2014, 08:12 AM   #3
Thanks for the reply.
I had somehow missed that there is an XL version of FH.
I should certainly be able to accommodate it in my room but I'm not sure about cutting the curves by hand so I'm going to investigate getting the panels CNCd. I have no problem with making a donation for the plans if this route looks feasible.
Will I get more bass from the FHXL than a Pensil (even a SuperPensil 12)?
Thanks again!
Chris
Old 10th May 2014, 03:40 PM   #4
zman01 is offline zman01  Bangladesh
Chris,
Probably the FHXL will go a bit lower than the Pensil or even the Super Pensil 12 - the FHXL design team can comment on that. I had the SP12 in the room and the sound was definitely good, but the cabs are around 19" deep from top to bottom, and WAF among other things was an issue. Recently completed a build of the FHXL and have been generally impressed with the sound across multiple genres including electronica. However please note that a lot of rock recordings sound a bit thin and may not be as enjoyable on revealing single driver FR speakers vs ones with large woofers... Having said that FHXL with the Alpair 10P is likely to be a good bet for a single driver system. Though the base of the FHXL is deep at 20+ inches, the overall design aesthetics still make it a visually pleasing.
Old 10th May 2014, 06:47 PM   #5
frugal-phile(tm)
planet10's Avatar
$10 to diyAudio ... a number have already happened.
In our experience, yes.
In terms of potential bass extension, the A12p is behind A10.3, A10p. The Mark Audio drivers with the potential to go the lowest were/are A10.2 and EL70.
The larger A12 cone means it can move more air, but i'll take A10p over A12p for everything it does better.
dave
Old 10th May 2014, 08:10 PM   #6
Be careful, you will have your work cut out to better the Naims.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 11th May 2014, 08:01 AM   #7
Thank you all for taking the time to reply and to consider my requirements!
Luckily WAF is not a big issue for me as my other half is very laid back about these kind of things
This was something that I was already wondering about and it's made me dubious as to whether FR is the way ahead for me. I do like quite a full, warm sound precisely because it's kinder to poor recordings.
So, I'm going to do some reading on the multi-way pages and think about whether that might be a better option for me. Or a sub-woofer.
Too many options!!
Do you mean I'll struggle to better them with a FR design, or with a DIY build full stop?
It is another thing I was somewhat concerned about... Part of me was thinking that as they are over 15 years old now things ought to have moved on somewhat, but they are good! (Mine also have upgraded cross-overs)
Having said that, if I make something and it isn't as good, it's not a disaster - I can use one or other pair in another room and I will still enjoy doing it and hopefully learn something, which at least half of the point of DIY, right?!
Thanks again!
Chris
Old 11th May 2014, 09:07 AM   #8
TNT is online now TNT  Sweden
TNT's Avatar
Just out of curiosity, could you name some CDs (?) that suffer from harsh sound?
Old 11th May 2014, 09:23 AM   #9
Yes (just for information I use a Naim CD3.5 and original rather than copied disks, and Naim Nait3).
Here are a few discs that spring to mind:
The Jesus and Mary Chain, Darklands - April Skies particularly
The Bluetones, Expecting To Fly - Cut Some Rug paricularly
The National - High Violet and Trouble Will Find Me
The Black Keys - El Camino
Red Hot Chilli Peppers - Californication
The White Stripes - Icky Thump
Suede - Coming Up
The first two are my tracks for testing equipment to see whether I'm going to be able to live with it.
Chris
Old 11th May 2014, 11:38 AM   #10
xrk971 is offline xrk971  United States
xrk971's Avatar
From the broad range of music that you like and your request for sufficient bass you might want to consider a design that uses full range drivers called FAST or Fullrange Assisted Subwoofer Technology. It is a 2-way crossed low around 120 Hz to 250 Hz and lets a full range driver be relieved if the lowest octave where cone excursion will cause distortion and also lack the power and punch of a large woofer there. Also you can use a smaller 3 to 4 inch full range on top and this has better highs and better polar directivity than a 6.5 or 8 inch full range. The easiest way to do a FAST is to bi-amp and use an active XO like a miniDSP. Back loaded horns are nice but it is tough to beat the overall ease and facility of sound that a well implemented FAST system can do. Just wanted to give you more options to think about. There are plenty of folks who can recommend the full range tops and woofer for you to try.
Good luck.
Still not sure where to start R1C0 Tubes / Valves 8 10th May 2013 05:30 AM
Will start my new Gainclone from Start, Need Help samsagaz Chip Amps 4 27th May 2008 09:39 AM
Where to start looking?????? Strummer61 Full Range 11 25th November 2007 10:30 PM
How should I start Alphas Chip Amps 9 6th July 2006 03:34 PM
Where do I start? damonpip Pass Labs 23 18th April 2006 08:58 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
