Hello friends! I'm writing to ask if any of you know or can measure for me the terminal width on the Alpair 10.3. I would like to order some quick connects to use while I'm playing with different cabinet styles but don't know what size to order. I was surprised that the Markaudio data sheet, which is otherwise so comprehensive, did not list that dimension. Thank you!
Mm
Mm
Dave, thanks for your reply! You say you don't use the supplied quick connects. Why is that? Only curious. I get nervous about soldering wire directly to the terminals and so I like the quick connect because that way I don't have to take the risk! I'm not a skilled with an iron as most on here though. I'm a woodworker, and not much of an electrician. =(
Fewer connections. Better sound.
dave
