Conical horn calculation - diyAudio
Old 19th April 2014, 11:24 AM   #1
Tyimo is offline Tyimo  Hungary
Default Conical horn calculation
Hi!
I read many nice thinks about conical horns for example on the Oswalds Mill Audio web site, but I saw nowhere how to calculate it.
Has somebody any info about it?
Is it possible to use Michael Zhang's ML util program for it??
Greets:
Tyimo
Old 20th April 2014, 10:42 AM   #2
Hmmm...
Old 20th April 2014, 11:55 AM   #3
Scottmoose's Avatar
Not all of us are here 24/7.
Google is your friend. Try typing 'Conical Horn formula' into it. I obtained 4,200,000 hits. Not all will be relevant of course, but there are many, many articles & papers on horns, a reasonable number of which refer to the conical type:
Simple derivation assuming free-space & full-sized terminus: Sl = St x^2
where
Sl = terminus CSA
St = throat CSA &
x = axial horn length
Conical horns are rather less efficient than a hyperbolic or exponential for e.g., and have linear expansion, so no flare frequency per se, but nominally at least distortion is low.
Community sites www.frugal-horn.com http://frugal-phile.com/
Old 20th April 2014, 03:13 PM   #4
GM is offline GM  United States
GM's Avatar
Don't see how, but I'm no great mathematician. Hornresp makes it simple enough though.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 20th April 2014, 03:25 PM   #5
xrk971 is online now xrk971  United States
xrk971's Avatar
Lots of good info here:
Horn Theory
Old 20th April 2014, 04:35 PM   #6
Thanks Guys!
Happy Easter!
Tyimo
Old 20th April 2014, 04:45 PM   #7
Scottmoose's Avatar
Horn Theory
Just so, but as I recall Martin focuses on the exponential profile & does not provide dedicated derivations for other types of expansion on his site, though he refers to them in a couple of sections.
Old 20th April 2014, 06:08 PM   #8
Conical horns 600Hz and up
My conicals I just finished. (Experimental)
Can send you the files I used if you want?
Old 20th April 2014, 06:48 PM   #9
GM's Avatar
None of your pictures display for me..........
GM
Old 20th April 2014, 07:02 PM   #10
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I have used this calculator simple
seems to work
but I don't know if the result is correct
mh-audio.nl - Bass Horn
planning to construct a mid/high horn for a 4" pro array widerange
it will be a vertical slit throat, and maybe with a vertical phase plug
but conical it is not
sometimes we know very little, and sometimes we know too much
Conical Horn + Midrange Enclosure iblanken Construction Tips 0 23rd May 2013 09:19 PM
Eric Forker's 77hz conical horn pumpkin1 Multi-Way 0 24th August 2010 12:43 PM
Conical Horn Dip MaVo Multi-Way 13 17th March 2010 09:25 PM
conical horn damping material... pauldune Full Range 14 14th March 2010 02:07 PM
Compensation for Conical Horn Sheldon Multi-Way 1 11th November 2006 11:01 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
