sy thanks for that link i guess it's been done in a larger scale then i was thinking of by a wide margin.
cal i was thinking the other way around; mount a small 2 or 3 inch wideband driver on the small (throat) opening and create exits around the driver into the large part (mouth).sealed could also work...
now i need to find a 3D printer!
or maybe just get some klein steins pour out some margarita's wait for spring and think on it somemore....
A Klein bottle is closed if you put driver at mouth. In which case it will be kind of like a sealed TL (if long enough). One could mount driver on wall of bottle and let mouth/neck serve as vent in a BR or TL or BLH. The aesthetics would look great in a real blown glass enclosure so you can see the Klein bottle topology. Otherwise looks like a bottle with a loop handle.
Hi Turk
You might be interested to see this post:http://www.diyaudio.com/forums/pass-labs/166784-pictures-your-diy-pass-amplifier-182.html#post3438566
I asked him about it and it's just a scaled down version of the 'HUGE' one Mr.Pass designed.
Ignore the fact the link says 'Pass Amps', Klein pic is about 1/2 way down the page.
sorry no scanner no cad i hope the attached photo is ok to depict what i was thinking.
depending on size could it not be turned into a mid horn or mid bass perhaps?
i keep thinking of it like a long back loaded horn
When I saw Hippy's 'Micro Klein', I sent him a pm asking for more details, quote:
He also said that the driver used had no details on the 2" drive unit he used other than it looked like a $20 Dayton.
the demensions are based off the ones in the pdf, except everything was devided by 3.2 which scaled it down for a 2.5" driver
Uh, April 1st was three weeks ago boys and girls
'Yeawotevva' - Vicky Pollard / Little Britain, 2000 and sumfink innit like.
- Full Range
- klein bottle enclosure
