Old 31st March 2014, 06:05 PM   #1
adri123 is offline adri123  United Kingdom
Default Capacitor as a crossover?
Hi.
I'm making a similar system to the one in this thread
Transmissionline Ipod Docking Station
I have the same Peerless drivers and a couple of cheap tweeters. The guy in the Transmissionline build says he just used a capacitor as a crossover. How can I tell which capacitor to use and how it's wired?
Thanks for any replies.
Adri
Old 31st March 2014, 06:31 PM   #2
lexer98 is offline lexer98  Argentina
lexer98's Avatar
that guy crossed the tweeter around 10 Khz ... so for a first order crossover the formula is C=0.159/(i*f)
i = impedance of the tweeter at the crossover point (if don't have it use nominal impedance)
f= Crossover frequency
Or use a crossover calculator xD
Sorry for my horrible English
Old 31st March 2014, 08:17 PM   #3
So where would the capacitor wire to?
Thx
Old 31st March 2014, 08:44 PM   #4
chrisb is offline chrisb  Canada
for a simple 1st order, in series with the + tweeter terminal (even though the filter components are in series with the respective drivers, this is referred to as a parallel network, as the drivers are in parallel with each other)
a basic on-line X-O calculator would return a diagram as below, as well as provide value for C:
when using a FR wide open, ignore the L1 LP filter leg
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 31st March 2014, 09:00 PM   #5
Thx v much all!
So all I need is a capacitor for each tweeter. I guess it'd be about right to go for the 10000 hz as per the transmissionline project I've referred to as he used the same peerless full range drivers so I'm just going for the very high frequencies to go through the tweeters.
Think I'm beginning to understand...
Thx again
Adri
Old 31st March 2014, 09:09 PM   #6
Another thing to consider is the relative efficiencies (loudness) of the drivers. The tweeter usually will usually have a higher SPL (sound pressure level) than a mid or woofer, so you will normally need to pad down the tweeter with a "L" pad or equivalent resistors to match levels.
Mike
Old 31st March 2014, 11:42 PM   #7
Jsixis is offline Jsixis  United States
Crossover Design Chart and Inductance vs. Frequency Calculator(Low-pass) have fun
1 capacitor is a 6db crossover so say for example 2uf @ 8 ohms 10,000hz
5000hz would be 6db quieter at 2500hz it would be 12 db quieter 1250hz 18db 625hz 24db.
I think that is correct.
Many speakers do cross over tweeters that high, some of the old tube consoles I saw used a 1uf cap at tweeters.
I know nothing, so learning is really awesome.
Crossover capacitor voltage andykap Multi-Way 9 1st January 2013 05:51 PM
Replacing a crossover capacitor? jtaylor2005 Multi-Way 36 31st July 2012 10:10 PM
Capacitor quality for crossover Nicola Multi-Way 10 22nd May 2010 11:17 AM
Can anyone help me ID this capacitor in crossover? silentblackhat Solid State 10 1st November 2008 01:35 AM
Capacitor type for crossover ThSpeakerDude88 Multi-Way 23 4th August 2007 09:00 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
