Old 28th March 2014, 08:44 PM   #1
Squeak is offline Squeak  Denmark
Squeak's Avatar
Default Opposed dual ports. Will it work?
Would a port like this work?
For a flat wallhanging speaker, I want to hide the bindingposts and this seems like good way to put them in the port, while still making them operable.
But will it work well with a split port with the two halves firing into each other?
Old 28th March 2014, 10:06 PM   #2
The port will be modified by the spacing to the rear wall.
but yes it will work, hard to predict how well it works.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 28th March 2014, 10:13 PM   #3
chrisb is offline chrisb  Canada
If this is to hang on the wall, where will the dual rear port slots exit?
As sreten said, it'd "work" in the strictest sense, but perhaps not easy to model / predict performance. I'd be inclined to isolate the 2 slots and exit them at the bottom
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 28th March 2014, 10:24 PM   #4
Squeak's Avatar
Part of me thinks that the some of each ports output will be lost into the other. Another part of me thinks that is BS. After all it's somewhat the same as having a port rather close to a wall, which works fine if it is not too close.
Or it could be argued to be the same as one port that has a 90 degree bend right before the exit.
Old 28th March 2014, 10:27 PM   #5
Squeak's Avatar
It's a squashed quarter wave with the port(s) at the bottom of the "frame".
Just a feeling or do you have something facts/physics to back it up? Thank's for your input anyhow.
Old 28th March 2014, 10:44 PM   #6
Scottmoose's Avatar
You'll probably get some turbulence, but assuming you don't go mad with the vent aspect ratio it should work ~'good enough.' Sorry, just lost my dog (some form of cancer) so not really up to going into much detail.
Community site www.frugal-horn.com Commercial site www.wodendesign.com
Old 28th March 2014, 10:49 PM   #7
Squeak's Avatar
I'm amazed you're even reading the forum. Welcome distraction? Losing a dog is for most people as bad as loosing a human. My condolences.
Old 28th March 2014, 10:51 PM   #8
Squeak's Avatar
It leaves the question though, what is "good enough"?
If you lose efficiency or get interference, I'll just do it some other way.
Old 29th March 2014, 01:16 AM   #9
99% of my musings are conjecture, the remaining 15% intuition, and even I'm not wrong all the time.
I don't think the question in my previous post was answered, is this to be mounted flush to the wall with the binding posts at the rear?
If so how much clearance were you planning on?
Old 29th March 2014, 02:57 AM   #10
GM is offline GM  United States
GM's Avatar
Hmm, this appears to be an acoustic high pass filter, If so, instead of enhancing the bass it will damp it down instead: Acoustics/Filter Design and Implementation - Wikibooks, open books for an open world
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Dual opposed Slot Loaded Port mattlong8 Subwoofers 42 21st March 2014 05:50 PM
Dual opposed midrange drivers, basket diffraction? OllBoll Multi-Way 2 6th November 2013 03:31 PM
Dual opposed Shiva sub with inuke1000dsp Zonneschimmel Subwoofers 17 12th April 2013 09:51 AM
Honeycomb composite panel enclosure, dual opposed configuration rhapsodee Subwoofers 6 1st September 2010 03:26 PM
Opposed dual driver sub woofer. tade Subwoofers 10 18th April 2005 09:51 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
