Ikea Blanda speaker, driver? - diyAudio
Old 20th March 2014, 10:12 AM   #1
oLjud is offline oLjud  Sweden
Default Ikea Blanda speaker, driver?
I just stumbled over a few picture of ikea blanda speakers and got very interested in building a pair of my own. But what FR-driver a suited for the new bamboo "blanda" bowls (12cm and 20cm)?
A few drivers I looked at:
for 12 cm:
Faital pro 3fe20
Scan speak 10F?
Tangband W3?
for 20 cm:
Markaudio alpair7
Tangband W4?
I have a (sub)woofer for the bass frequencies.
Website: mikaelhornqvist.wordpress.com
DIY-project: 2x BC 8BG51/speaker with Beyma CD10Fe+TD194. THAM15. Open baffle with 2x alpha15/side
Old 25th March 2014, 08:10 PM   #2
stevieg is offline stevieg  United Kingdom
These have a cheap Visaton 3.3". Please note that Blanda bowls are not perfect matches, and not quite hemispherical. You can deal with both these issues by using an insert between the bowls. This insert can help you to make a stand, furnish ports etc.
Note superb cabinet work - but you get the idea.
Cheers Steve
steve
if it ain't broke, I ain't fixed it
Old 26th March 2014, 04:48 PM   #3
Stevieg, what are the dimensions of your ports?
Sendt fra min SM-N9005 med Tapatalk
Old 26th March 2014, 04:54 PM   #4
tomchr is offline tomchr  United States
tomchr's Avatar
I was planning to use a TangBand W5-1611SA in the larger bowl. That should be about right. However my plans changed, so now I have a pair of W5-1611SAs sitting around. PM me if you're interested.
~Tom
21st Century Maida Regulator, Universal Filament Regulator, Damn Good 300B, Novar Spud, and more...
Neurochrome : : Audio - http://www.neurochrome.com/audio - Engineering : : Done : : Right
Old 28th March 2014, 12:06 PM   #5
Dear Mad Max - Can't remember I worked out the dimensions with an on line port calculator. Seems to work OK. I was limited by the thickness of the spacer, and availability of pipe. A more elegant solution is to use thin ply, and build the port(s) into the spacer.
Cheers Steve
steve
Old 4th April 2014, 10:05 PM   #6
Mine were sealed. I like sealed speakers, and I like MarkAudio, although haven't tried this combination together. If you can augment the lowest frequencies with subs/woofers, then all the better.
Old 28th July 2014, 11:26 AM   #7
Mayuri is offline Mayuri  Finland
Mayuri's Avatar
Here's my version of the Blanda speaker. I settled to CHR-70 instead of Alpair 7 due to the price, but seeing that the enclosure works quite well, I'll probably do the next build with Alpairs.
Originally Posted by Mayuri View Post
Spherical enclosures with MarkAudio CHR-70 gen 3.
Old 28th July 2014, 11:41 AM   #8
esgigt is offline esgigt  Netherlands
Looks great!
Old 30th July 2014, 11:41 PM   #9
tomchr's Avatar
Mayuri: Which bowls are those? They don't look like the IKEA Blanda series.
~Tom
Old 31st July 2014, 04:01 AM   #10
Mayuri's Avatar
They are the IKEA Blanda Matt 28cm diameter bowl. I made a 2 cm thick spacer ring between them because the bowls aren't perfect semi-circles, they are only 13cm high.
Concept, Beolab 11 style isobaric sub using Ikea Blanda metal bowls. Studio Au Subwoofers 47 16th January 2013 01:21 AM
cheap fullrange speaker dy1026u in Ikea-box Hatti Full Range 10 18th October 2011 04:49 PM
Tutorial: building IKEA baffleXchange speaker cabinets CharlieLaub Multi-Way 1 25th August 2011 07:43 PM
Ikea bowl speaker drivers polop1 Full Range 61 29th January 2011 08:38 AM
WTB: 4x Ikea BLANDA bowls, 8" or 12" Spasticteapot Swap Meet 7 11th March 2010 05:46 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
