MA driver measurements - Page 5 - diyAudio
Old 8th April 2014, 12:57 AM   #41
xrk971 is offline xrk971  United States
xrk971's Avatar
GM,
I think I was referring to amplitude ratios while you are referring to power ratios which is square of amplitude as P=V^2/R?
In amplitude signal world dB = 20 log(Vhigh/Vlow)
Old 8th April 2014, 01:09 AM   #42
xrk971's Avatar
BMS,
I wonder if rectilinear cabinets tend to have more of a problem with internal reflections. In my curvy walled DCR, the impulse looks pretty clean and free of reflections. Not a A7.3 but here to demonstrate effect of non rectilinear walls on IR.
And here is same driver IR in an open baffle.
Old 8th April 2014, 03:04 AM   #43
5th element's Avatar
In my experience the only way a cabinet tends to mar a drivers distortion performance is if the rear of the cone is extremely covered up by the cabinet. If it's free to breathe then the box wont typically cause any issues.
Normally though, if box resonances or reflections are the culprit they tend to show up only at specific frequencies, rather than being broadband. They also show up in the impedance plot as wiggles or bumps, deviating from what you'd expect from a purely inductive rise. Of course you'd need to compare the driver measured in free air vs in the cabinet to see if any bumps were showing up. Full range drivers typically display a number of these anyway as exploiting resonances is inherent to their design as a way of extending the high frequency response. Getting this effect comes at a price though because lightening the cone causes it to be less pistonic further down in the midrange, so you get issues occurring there too. Now full range drivers aren't the only ones that succumb to these mid band resonances, as other heavier soft cones do too. Heavy, very rigid cones, like the SEAS excel drivers, are completely free from any resonances, except of course for their bell mode resonance high up in frequency.
Nevertheless, if you wanted to pin box resonances/reflections on the problem, you'd need to make sure the bumps you were seeing in the impedance were actually being caused by the box and not the driver.
The dip encountered at 1.2kHz is unlikely to be box related as this is present in Mark's own measurements, but the box could quite easily be designed to reduce its effect. 1.2kHz is smack bang in the frequency range where the primary diffraction peak can show up for cabinets with the range of widths we're talking about using with these drivers. If you designed the width accordingly it would compensate quite nicely for the inherent dip. Also some internal cabinet reflections/resonances could help to reduce its effect too, or make it worse, but this would be incredibly unpredictable and getting the compensatory effect from cabinet diffraction would be a much better choice - this could explain why some peoples measurements present with the dip and some don't.
In any case the simplest way to confirm measurements, one way or another, would be to get a 50x50cm baffle of MDF, flush mount the driver in the centre of it, chamfer the rear of the cut out and do some gated far field measurements in a properly configured room (ie one that's had all reflective surfaces from furniture etc removed). I would also suggest using STEPS to perform distortion measurements, that is rather than swept sine stimuli as it tends to give better end results.
Yes the 50cm baffle wont be large enough to give low end accuracy and no doubt your room wont be either. But it should be good enough to satisfy anyone's doubts as to the measurements usability from around 400Hz and up.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 8th April 2014, 02:59 PM   #44
GM is offline GM  United States
GM's Avatar
Originally Posted by xrk971 View Post
GM,
What I posted are power ratios, yours are voltage ratios, so must be converted back to power ratios for response plots as I understand such things.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th April 2014, 08:30 PM   #45
Something about mesurments, it isn't that simple!
Loudspeaker Measurements
Old 9th April 2014, 08:52 PM   #46
chrisb is offline chrisb  Canada
gee, if we were looking for something simple and absolute, we probably need to find another hobby
... so, not as easy at it sounds, this letting go thing
Old 9th April 2014, 09:02 PM   #47
Speakerholic
Cal Weldon's Avatar
That's why I have two hobbies. Speakers and drinking. If one isn't working at the moment, the other probably will. See? It's not that hard.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 9th April 2014, 09:08 PM   #48
yes, of course, the second one does easily encompass Absoluts - nicely done Cal
Old 10th April 2014, 01:22 PM   #49
mondogenerator's Avatar
True. I haven't measured my MA A5, and I'm not slighting the brand either, BUT mine exhibit an AUDIBLE resonance at almost exactly 400hz, which isn't obvious on the published specs.
These plots could be inaccurate, hesitant to say that.
OR the resonance isn't easily found through a FR plot alone.
There is alot a measure excludes as well as the info it shows
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 10th April 2014, 02:10 PM   #50
R-Carpenter's Avatar
What was exact measurement conditions? Did you merge near and far field data?
Gating and so on?
Is this only one automated gating and no near field splice?
Measuring Mark Audio Alpair-10 gen-2
http://www.diy-ny.com/
MA Driver Choice eaglears Full Range 34 12th December 2012 07:00 PM
Slightly creased driver MA CHR-70 Tripmaster Full Range 6 25th September 2012 09:13 AM
Crown MA-12000i / MA-5000i / MA-9000i jack2040 Solid State 4 8th March 2011 02:21 PM
Driver measurements Legis Multi-Way 0 12th October 2010 07:08 PM
Copyright 1999-2017 diyAudio
