L. Cao F6 - very nice with Karlsonator 6 - diyAudio
Old 27th February 2014, 06:09 AM   #1
freddi is offline freddi  United States
freddi's Avatar
Default L. Cao F6 - very nice with Karlsonator 6
F6 sounds lovely on classical bass viola - very sensitive, excellent top end - beautiful. Greg B's little (~12X12X21") Karlson variant is good compliment and probably more effective/better sounding than a larger volume lower tuned ML-TL. Detailed plans for the Karlsonator 6 can be found at fullrangedriver buried in the Karlson section
Old 27th February 2014, 09:42 AM   #2
freddi's Avatar
with good recordings, the little Karlson variant and F6 L.Cao play nicely & smoothly on vocals. flamenco guitar, cello & piano sonata. There's no need for any helper tweeter. For those not familiar with Greg B's design, here's a drawing (a larger plan is downloadable from his album)
Old 27th February 2014, 01:01 PM   #3
xrk971 is online now xrk971  United States
xrk971's Avatar
Freddi,
Is that a 6 in driver or 8 in? What is the Qts on that driver becaus when I looked it seemed like they only had 8 in drivers and the T/S specs were not obvious. Looks cool with that yellow cone - what is that made of?
Old 27th February 2014, 07:04 PM   #4
Godzilla's Avatar
I have an old, unused box from a discarded vintage AR speaker that's just about those dimensions. Maybe I can convert into a Karlson?!? So that's a six inch version or can I use an eight inch driver?
I have a Fostex 168z... will that work?
Old 27th February 2014, 07:33 PM   #5
xrk971's Avatar
'Zilla,
If you want to convert a box to one with a Karlson aperture, I suggest the Karlsonator as shown above and not a Karlson proper (multi-chambered bandpass reflex style a la K15). Those do not scale well below 12 in driver at all (no bass). A Karlsonator scaled for a 6 in or 8 in driver can work very well - check out some of the sims in the Karlsonator thread. My guess is FE168Z can work well. I may have sim'd it already can't recall off hand.
Old 27th February 2014, 08:26 PM   #6
freddi's Avatar
here are the specs on the F6 model - -cone diameter is roughly 5" not including the surround. Add 1/2 of the surround and its ~5.125" diameter - so SD for the F6 would be ~130sq.cm vs 88.25 for an Alpair 10P, or 147.41 for 12P.
search Ebay with these terms "match pair 2pcs Lcao HiEND 6.5inch fullrange speaker ,PK lowther fostex"
Zilla - if your box has this aspect then you might make a Karlsonator - otherwise it probably would still convert to some sort of K - probably with higher cutoff. Rear volume should not go below (Vas*fs*qts)/50 as a rough rule.
F6 spec (there's also an alnico version at 3X the cost) - I think F6 would be appreciated by FR lovers. Delivery was very fast - maybe a week or so from China.
Old 27th February 2014, 10:38 PM   #7
Greg B is offline Greg B  United States
I concur with xrk971: a scaled 'standard' Karlson will not have deep bass. Karlsonator is a better choice, but of course I am biased. The specs for the old FE168Z are ballpark, so it should work, but I haven't tried to sim it.
Old 4th March 2014, 01:19 AM   #8
freddi's Avatar
hey guys - what kind of K do you think would be most appropriate for a little B&C 10" with the following spec? a 12" could be used but this would be "cute" and probably very potent with an internally mounted K-tube with decent compression driver coming in around 1K8 - not sure if the 5mm xmax could be used without audible "gargle" - might get another dB sensitivity with half that much xmax in a B&C10. Eminence has a new 10 called LA10850 which may play well but the B&C has the prettier frame
Eminence
LA10850 spec - fwiw it has low moving mass and a 4" coil so thermal compression may be relatively low
http://www.eminence.com/pdf/LA10850.pdf
the goal would be good quality sound and have more punch than a direct radiator or blh. Of course the K-tube could be mounted on top and still blend well. The result would have better treble power response than 6-8" fullrange drivers and hopefully do 120dB peaks without strain.
Product Specifications
Nominal Diameter10"
Power Handling (RMS)250 Watts
Power Handling (max)500 Watts
Impedance8 ohms
Frequency Response65 to 3,000 Hz
Sensitivity98 dB 1W/1m
Voice Coil Diameter2.5"
Thiele-Small Parameters
Resonant Frequency (Fs)63 Hz
DC Resistance (Re)5 ohms
Voice Coil Inductance (Le)0.9 mH
Mechanical Q (Qms)3.4
Electromagnetic Q (Qes)0.25
Total Q (Qts)0.23
Compliance Equivalent Volume (Vas)0.95 ft.
BL Product (BL)16.4 Tm
Diaphragm Mass Inc. Airload (Mms)34g
Maximum Linear Excursion (Xmax)5 mm
Old 6th March 2014, 01:19 AM   #9
KaffiMann's Avatar
Freddi:
Those F6 thingies really do look nice. What is your opinion on the 800hz dip?
Can not imagine how they managed to get so even response to 10khz 95db/2,83v with a 6" FR. Is that xmax value realistic? Better with or without the suggested smoothing filter?
Old 6th March 2014, 03:42 AM   #10
freddi's Avatar
hi KaffiMann - I'd imagine the 3mm figure to be peak to peak - - my box may have a dip in that area but things sound pretty good. I've not tried their filter -- from reading on another forum the filter suggested for one of their 8" wasn't centered properly.
Look at the impedance test I just ran on the unplayed F6 - that's one clue how they're getting good treble extension - impedance at 20KHz is only 10 ohm http://i.imgur.com/lPXJYKl.gif
Mini Karlsonator (0.53X) with Dual TC9FD's xrk971 Full Range 1913 23rd February 2017 11:04 PM
Karlsonator Greg B Full Range 265 27th September 2016 12:30 PM
L CAO in OB W/ Eminence Woofer Nelson Pass Full Range 134 26th July 2012 09:53 AM
New 8" full range speaker from L CAO HighVividity Vendor's Bazaar 40 8th February 2009 12:21 PM
F6 traw Pass Labs 7 2nd November 2007 08:09 PM
Copyright 1999-2017 diyAudio
