Short Line Array (line source) build
Old 23rd February 2014, 12:58 PM   #11
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
FAST? It's a popular and extremely irritating term (to mugs like me) for 'Fullrange And Subwoofer Technology.' Quite why subwoofers have suddenly become 'technology' while everything else presumably isn't seems mysterious. There is an alternate translation: 'Fullrange ASisTed' which is as lame an acronym as you're likely to find south of 'PRAT' (give me strength...). As an alternative, you could call them what they always used to be called: a 2-way loudspeaker. Rant over.
As for the array, the 3in version would likely be preferable if the subs can manage 200Hz with some grace, but they'll still need Eq to counter the declining HF trend inherent to the configuration.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 26th February 2014, 07:26 AM   #12
perceval is online now perceval  Taiwan
perceval's Avatar
FAST, got it. Indeed , not the best acronym but in this age of Facebook and the likes, we are likely to see more and more!
Hmm.. I just realized the 4" version is 4 Ohms, which may be hard on my receiver at the moment. The 3" is 8 Ohms, so it may be more appropriate.
My subs do not go much over 140Hz, and when I hear subs that do, I feel I can pinpoint them, which is not something I like in a sub because they are not perfectly located next to the main speakers.
Since this is my first foray into line source, I might just do it with the 3" drivers, and see how it goes. There's nothing like hands on experience! Of course, your input is always welcome!
Old 27th February 2014, 07:10 AM   #13
Colin is offline Colin  United Kingdom
It depends how many drivers you use. An array of four 4ohm drivers in series/parallel will give you a 4 ohm array. Add another in series and you have an eight driver array at 8 ohms :-)
Old 27th February 2014, 07:43 AM   #14
perceval's Avatar
Well, I ordered those 3" just before your post, Colin.
Got 16 of them heading their way.
I was wondering, if I wire them as 4-2-2, that'd be ok? that would give me a change from 8 Ohms to 6.4 Ohms... if I got the calculation right!
I would wire the outer 2 drivers up-and-down as the 4, then more power to the center ones as 2-2. In between will be a tweeter... later. I want to test different configurations.
Old 27th February 2014, 08:50 PM   #15
chrisb is online now chrisb
Scott - in the interest of mitigating your blood pressure, I'll henceforth only use the term Low XO 2-way - can we coin an acceptable acronym for that?
like my mind, this space intentionally blank
Old 28th February 2014, 10:36 AM   #16
Scottmoose's Avatar
2-way? LXO?
Old 28th February 2014, 11:51 AM   #17
geraldfryjr is offline geraldfryjr  United States
Here is a project that is underway that might spark your interest as well,
http://www.diyaudio.com/forums/multi...ml#post3789049
It uses 12 HiVi B3N 3" drivers and 12 tweeters of some buy out types per cabinet,
HiVi B3N 3" Aluminum Driver Round Frame | 297-428
http://www.diyaudio.com/forums/multi...ml#post3794305
It will be wired for 6 ohms with a 6.5Khz 12db passive crossover.
The plan is a ported 2 cubic foot enclosure tuned to about 41Hz.
With only 8 drivers it is best to keep the voltage across all of them equal so you are only limited to 4 ohms or 16 ohms.
If you had planned for 9 drivers then you could have 8 ohms per cabinet.
It is too bad that I didn't catch this thread before you ordered them.
The drivers themselves look good though.
I would definitely try them open backed (dipole) First and add separate woofer as suggested.
Although you may/will have to add some EQing to make them flat on the low end.
Your data sheet doesn't state the Xmax that the driver is capable of.
FWIW
jer
Old 28th February 2014, 01:57 PM   #18
perceval's Avatar
sweet!
Yep, that's the plan.
Want to try a bunch of configurations. The supplier is local, so if I need a few extra drivers, it will be easy. Didn't think about the 9 drivers being 8 Ohms.
anyway... drivers are coming in tomorrow!
Old 28th February 2014, 06:56 PM   #19
Greebster is offline Greebster  United States
Greebster's Avatar
I would not run them dipole/OB. If placed near a wall like you want causes issue with dispersion and messes up the frequency response. Even when properly designed can and does make a mess of things near any wall.
Old 1st March 2014, 01:47 AM   #20
perceval's Avatar
Ok, I remember why I went with 8 drivers.
My plan was to use 2 sets of four drivers, with a crossover between them. First set of four (wired 2-2) would handle up to 500Hz, and the other set of four drivers would take over from 500Hz to 3,000Hz and let the tweeter handle anything higher.
Am I correct in assuming that I would be at 8 Ohms?
Short Line Array (line source) buildHide this!Advertise here!
Line array surrounds or point source? mazeroth Multi-Way 9 6th March 2012 11:33 AM
HT Line Array and T-Line Build tHEbLENNY Multi-Way 7 29th February 2012 04:58 PM
Tymphany LAT250 line source array? elves1111 Planars & Exotics 11 17th September 2011 08:03 AM
Aurasound speaker for short line array? MPM Full Range 5 6th September 2005 12:51 PM
Help with line source array subs!?!?! Turboegt Multi-Way 12 29th December 2003 04:02 AM
